hi all,
the first of many posts.
i am having some trouble with an IR extender kit.
my TV is mounted on the wall & i have the AMP in a cabinet behind me.
i've run HDMI, optical, etc all through the wall/ceiling & some figure 8 for an IR extender.
i purchased a DIGITECH AR1812 from jaycar (under 5 posts cannot post links)
the guy in the store told me it would work fine for cabled distances of up to about 70 meters
the cable i ran in the wall was about 10m
the cords have about 6m on each receiver & emitter
so all up i'm looking at 22-23m
the power indicator light on the HUB comes on but nothing happens when i use the remote
i pulled my extended figure 8 off & connected the receiver & emitter directly into the HUB this time a blur
indicator light appeared on the receiver when i sued the remote & volume on the AMP changed. *working!*
so i thought it must be my wiring, so i pulled everything apart & re-soldered all the points taking extra care this time.
reconnected everything &... nothing.
pulled it all apart & tested with just the receiver & emitter directly into the HUB & nothing.
WTF?
it seems that if the unit is plugged in without the extended cable i got it to work once but when i reconnect the extended figure 8 not at all.
wondering if you think this is a dodgy unit or am i doing something wrong?
any help would be greatly appreciated
sam
WTF?
sam
