How can I control the volume on my stereo with my tv remote? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss How can I control the volume on my stereo with my tv remote? in the Home Theater | Audio and Video forum; How can I control the volume on my stereo with my tv remote? I would like to control the volume on my stereo by just pressing the volume up or down or mute ...
Old 03-18-08, 01:46 PM   #1 (Link)
New Member
Alias: drew
Loc: Kentucky
User: #18376
Since: Mar 2008
drew is offline
I would like to control the volume on my stereo by just pressing the volume up or down or mute on my television remote. I don't want to have two different remotes sitting around all the time. Is there a way that allows my tv remote to control the volume on my stereo? Thanks for your time.
Drew
Old 03-18-08, 02:38 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: How can I control the volume on my stereo with my tv remote?
Welcome to the Forum, Drew!
Sorry, but unless your TV has that feature built into the remote, you won’t be able to do it. The manual will tell you.
There are alternatives, however. Often the stereo remote can be programmed to control the TV, for instance. Barring that you’d have to get an after-market programmable remote that could learn the functions of both remotes, allowing you to use only the one.
Old 03-18-08, 02:47 PM   #3 (Link)
New Member
Alias: drew
Loc: Kentucky
User: #18376
Since: Mar 2008
drew is offline
I am currently using my satellite remote to control my tv volume and that works fine. But when I have the stereo hooked up to the tv audio, any time I want to mute the tv I have to grab a different remote and mute it. I was wondering if you could tap into the tv speakers and let that audio drive the sound to the stereo, therefore when you mute the tv speakers you would also be muting the stereo speakers. thanks for you input.
Drew
Old 03-18-08, 03:54 PM   #4 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
the only 2 options you have is to get a programable remote like the Harmony 880 by Logitec or if your TV has a variable line output (rca) on the back of it. You can then run the Sat audio into the TV and then out to the receiver. There is sometimes a setting in the TVs menu that will change the output from "fixed" to "variable".
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-20-08, 01:08 PM   #5 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Yup, I'll second the Harmony recommendation. TV remotes that will control a receiver are pretty rare. Often times the receiver remote will work ok with the tv, but not the other way. I could never get the Satellite remote to control the receiver either.
Mark
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Plus/2 volume control problem - scratchy coffeeman SVSound 8 12-14-07 08:47 PM
tweeter volume control vince DIY Speakers 4 10-24-07 12:23 PM
Universal Remote Control lcaillo Manufacturer and Vendor Reference Information 0 05-01-07 07:18 PM
Remote control changes channels on both receivers BradGinter Remotes | Cables | Accessories 7 01-30-07 02:07 PM
Sub Volume Control and Fletcher-Munson paulnclark System Setup and Connection 5 12-29-06 11:06 PM
Mach 5 Audio
