Voltage Stablizers... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Voltage Stablizers... in the Home Theater | Audio and Video forum; Voltage Stablizers... I have been reading with great interest the threads about surge suppression and power conditioners. I thought I would put ...
Old 07-17-06, 03:10 PM   #1 (Link)
Alias: Rolyasm
Loc: Utah
User: #1522
rolyasm is offline
I have been reading with great interest the threads about surge suppression and power conditioners. I thought I would put out the next question regarding power, and that is the voltage stabilizers. Not even sure who makes them, besides MC. The way I understand these units is that they keep a constant 120v going to your system. No spikes, no dips. I can definitely see the need for surge supressors, kind of sometimes see the need for power conditioners, and don't have an opinion on voltage stablizers. Anyone have an opinion, or better yet, facts?
Roly
Old 07-17-06, 04:54 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Voltage Stablizers...
PS Audio produce several power plants (regulators) of various sizes (300w/500w/100watt). They are quite expensive and do the job they're intended to do.
Basically these devices are AC to DC to AC converters. They receive the AC from the wall and convert it to DC the same as the power supplies in all your audio equipment that you own. Then they feed a very high quality AC inverter to create a new AC signal to feed your equipment. Well, if the AC power in your home isn't a problem to begin with (and it usually isn't), what have you gained here? You already have a device in every piece of equipment you own to nicely convert AC to DC with a rather high noise rejection. Why do it again and then reconvert the DC back to AC and then feed it to a power supply and recreate DC again. Is the AC coming from the AudioPlant going to contain less noise and harmonics from the wall? Maybe, maybe not - and anyway, the noise rejection of a standard power supply in a piece of audio equipment is very high. You'd be adding another device into the chain. How many times do you want to go back and forth from AC to DC?
Take for example the model PS300. It only supplies 300 watts. A standard 15 amp wall plug can supply about 1800 watts. Should you limit the power to your equipment to 300 watts, particularly when most residential power is not flawed to begin with?
Old 07-17-06, 05:16 PM   #3 (Link)
Alias: Rolyasm
Loc: Utah
User: #1522
rolyasm is offline
So say the wattage drops from your wall, for whatever reason, as claimed by the VS makers. Does this cause any undue stress upon your receiver or components? Do the converters in the equipment care if it drops or goes a little higher every now and then? I think that is what these companies tout is that even if there are peaks or dips, your equipment ALWAYS sees the same power input, whereas without it it might be higher or lower. Whether or not this causes a problem, I have no idea. If the onboard converters don't care, I guess it wouldn't be.
Roly
Old 07-17-06, 05:41 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
The DC power supplies in all your equipment will accept quite a wide variance in the AC it receives. No problem.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
