Long HDMI Cable Run Solution - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Long HDMI Cable Run Solution in the Home Theater | Audio and Video forum; Long HDMI Cable Run Solution TRIBUTARIES® Bows Long-Run HDMI™ Solution April 26, 2006 TRIBUTARIES Cable, manufacturer of high-end audio and video cabling and accessories, has ...
Old 05-01-06, 11:41 PM   #1 (Link)
Loc: Lower Alabama
April 26, 2006
TRIBUTARIES Cable, manufacturer of high-end audio and video cabling and accessories, has debuted a new enhancement for the rapidly spreading HDMI™ digital-audio-video interconnect standard. The new DSR-701 Digital Signal Restorer from Spectrum Electronics, ensures full performance from HDMI™ connections over cable-runs as long as 45 meters/148 feet. HDMI™ (High-Definition Multimedia Interface) is rapidly becoming the universal standard for interconnecting digital televisions, including HDTV monitors and sets, with digital-video sources such as digital-cable set-top boxes, DVD players, and DTV tuners, and will be the connection of choice for forthcoming high-definition DVD standards.
The DSR-701 automatically analyzes the incoming HDMI™ signal and applies equalization to ensure optimum performance through the connected length and quality of cable. This correction ensures complete data restoration on the incoming signal to HDMI™ specifications, minimizing data loss by the receiving component, with full quality for all DTV resolutions up to and including 1080p, or computer-monitor formats up to UXGA.
The DSR-701 is engineered to lock on to even a weak HDMI™ data-stream and restore it to full-bandwidth integrity: the DSR-701’s Data-Lock Sensor LED illuminates red when the unit first detects a signal, and changes to green to indicate full lock and restoration. The DSR-701’s circuitry is direct coupled from input to output and is designed with fully balanced-line signaling and self-diagnostic monitoring. Complying with HDMI™ Standard 1.1, the DSR-701 delivers fully automatic signal-equalization of up to 40 dB at 1.65 GHz, and extends interface length to 30 meters (98 ft) with 28AWG STP (shielded twisted pair) HDMI™ cable, 40m (131 ft) with 26AWG STP, and 45m (148 ft) with 24AWG STP cable.
The DSR-701 Digital Signal Restorer for HDMI™ connections is constructed on an all-metal chassis using ultra-high-frequency surface-mount technologies, and is supplied with an outboard, 3.3-volt DC power supply.
Available now with an MSRP of $349.
Source: Tributaries Cable Press Release
Sonnie
Old 05-25-06, 04:42 AM   #2 (Link)
Alias: ocdpc
Loc: I ain't tellin ya!
User: #754
overclockedpc is offline
Re: Long HDMI Cable Run Solution
I'm beggining to think that HDMI is just a gimmick to get people to buy all the fancy, expensive gadgets you need to get a good signal...
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
