How many of you built your own cables? - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss How many of you built your own cables? in the Home Theater | Audio and Video forum; How many of you built your own cables? bpape wrote: I need some new AC cords and refuse to pay the outrageous prices some of the companies get. ...
Old 01-31-07, 05:56 AM   #26 (Link)
Alias: Bryan
Loc: Edwardsville, Illinois
muse77's Avatar
User: #4838
Since: Dec 2006
muse77 is offline
Re: How many of you built your own cables?
bpape wrote: View Post
Bryan
Newark has shielded cordsets for about $14.00
A different Bryan
Old 04-02-07, 06:40 AM   #27 (Link)
New Member
Alias: Tee
Loc: Florida
User: #7924
Since: Apr 2007
infrasonics is offline
I've made plenty of cables, mainly using Belden 1694A with Canare RCA's and F connectors. I invested in the expensive Canare crimps and dies, and while they were not cheap I more than made up for it by constructing many sets of cables. My time was cheap, considering I did the cable construction while watching videos/TV. I like the ability to make the correct length and personal color coding of the boots/shrink wrap.
Old 04-02-07, 06:42 PM   #28 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Names like Belden and Canare cost an arm and a leg here..particularly when you need to have a number of 10M..runs..
I had never tried making my own cables before, but since my present setup required long runs, I decided to give it a try..
Always looking for the easiest way, I bought a roll of RG6 quad shield and a number of "twist on" F type connectors to RCA plugs..
Couldn't have been easier..The twist-ons require a bit of elbow grease, but once on they really hang on..and of course no crimping tool required..
I can't imagine any commercial cable would perform any better over that distance..
Old 04-02-07, 10:11 PM   #29 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Your call - but I'd personally never use the twist ons. I want a SOLID, TIGHT, PERMANENT connection - which the twists aren't. The diff in price between that and the Belden/Canare combo - even with tools when doing lots of long runs is trivial in the grand scheme of things.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-02-07, 10:32 PM   #30 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Well I guess I'm a bit of a miser at heart..If I can save a few bucks here and a few bucks there, and not suffer for it, then that's the general road I take..
But seriously (and I'm not calling Shirley!) do you think you are getting any better video quality, using those brand names than what I'm getting with my ghetto cables?
Old 04-03-07, 11:54 AM   #31 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
I used twist-on F-connectors back before I got a good crimper. They’re still in my system, ten years later. They will work fine for coaxial cable, as long as they’re installed on the cable properly, and as long as you know and respect their limitations.
First, I’ve had them fail when used in attics. So avoid that. Apparently they don’t do well with the constant changes in humidity and temperature (although I have no explanation why crimped connections wouldn’t have the same problem).
Second, I’ve seen them fail in situations where the connection is handled a lot. If you’re say, an equipment reviewer who’s always shuffling new gear in and out of your system, you should probably avoid using twist-on F-connectors.
Aside from that, they work fine in “set it and forget it” installations, such as in-wall cable TV outlets, and even in an equipment rack that’s only occasionally disturbed.
With any coaxial cable, proper installation of the F connector is what makes or breaks it. If the connection is bad, it’s usually apparently immediately, visibly, on the screen.
Prof. wrote: View Post
The only concern I have about your installation, is the quadshield you used. Really, quadshield is only needed if you happen to live in really close proximity to a high-powered broadcast tower. I guess extra protection never hurts, but from what I understand RG-6QS typically has a steel center conductor that’s copper plated. That’s fine for the RF signals the stuff was made for, and it probably isn’t affecting your installation one way or the other, but personally I just prefer solid copper for my audio and video signals. I generally prefer RG-59 mainly because it’s more flexible and easier to work with, and works just as well as RG-6 for line-level video signals.
Old 04-03-07, 12:15 PM   #32 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Agree with what Wayne said. I've used them OK for pretty permanent things and for usage like a secondary cable TV hookup, etc. For my RGBHV, HD component video, SPDIF audio, etc - I'll stay with the crimp ons.
If they'll fail as outlined above, then even in less strenuous situations, there will be a less tight connection that can allow air/moisture/corrosion to begin which is the bane of any signal that counts on impedance.
Bryan
Bryan Pape
GIK Acoustics
Old 04-03-07, 07:06 PM   #33 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
I totally agree and they can be a problem if not connected properly..My first attempt failed after following the advice that was given by the person that sold them to me..
After trying different ways of twisting them on, I found the right way of making the connection, and after repeatedly trying to pull them off again, could not budge them, so I figured that even if I did have to remove them from the equipment from time to time, they would be ok..
The only concern I have about your installation, is the quadshield you used. Really, quadshield is only needed if you happen to live in really close proximity to a high-powered broadcast tower. I guess extra protection never hurts, but from what I understand RG-6QS typically has a steel center conductor that’s copper plated. That’s fine for the RF signals the stuff was made for, and it probably isn’t affecting your installation one way or the other, but personally I just prefer solid copper for my audio and video signals. .
I have major power lines that pass out the front of my place, so the RG6-QS is almost a must..
I generally prefer RG-59 mainly because it’s more flexible and easier to work with, and works just as well as RG-6 for line-level video signals..
This is one thing I do find annoying with the RG-6..You just can't make tight bends with it..But all of my connections are behind the screen wall (except for the projector) so no one sees them...
I would prefer to use RG-59 particularly for the leads to the projector, but I don't know if they would give me sufficient protection from interference..
Old 04-03-07, 07:13 PM   #34 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Bryan..I had to use pliers to screw these things on..I don't think their going to move anytime soon...
What I did find is that not all RG-6 cable is the same diameter, so if it's not matched up to the twist on, then I agree, it's not going to be a solid connection..
Old 04-03-07, 07:59 PM   #35 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
That shouldn’t matter at all as far as having to use quadshield. EMI is only a problem if the electrical and signal cables are right up against each other (parallel) for a considerable distance.
Actually, I’m surprised you could find some twist-ons for QS... Maybe that’s why you had to use pliers to get them on? That shouldn’t have been necessary.
Well – ten years I’ve been using these, and I live in Houston. Not many places more humid that this! Air conditioning helps, I suppose. Not sure how moisture and corrosion can be issues with an indoor installation.
Old 04-03-07, 08:30 PM   #36 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Wayne...The Belden cable was too big a diameter to fit the twist-ons, and I had to use a local brand of cable that was slightly smaller..Even then it was a tight fit...
While we're on the subject of video cables..one thing that I have always wondered is if the copper clad steel cored RG-6 cable has an impedance of 75 ohms..how can the solid copper core type still have the same impedance? Isn't video source equipment supposed to be matched to 75 ohm cable?
Old 04-05-07, 01:27 AM   #37 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Actually, coaxial was designed for RF signals, not line-level video signals. It just happens to also be highly suitable for video. (It works great with audio, too.) We just prefer copper because it’s a better conductor for electrical signals. I also prefer that the shield be copper, too, but that can be difficult to find.
The center conductor really has nothing to do with the cable’s 75-ohm rating. As far as I know, that has more to do with the construction of the cable, but I’m not sure exactly what. I’ve seen 75-ohm-rated coax in a variety of center conductor metals.
Wayne A. Pflughaupt
Old 04-05-07, 05:58 AM   #38 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Wayne.
Do a long term experiment. Take a pc of speaker wire and strip off a couple of inches of the jacket and just let it lay in a box somwhere in the house. Go back in a year and cut off an inch off the other end and strip that back a couple inches. Look at the difference. Moisture, corrosion (more correctly oxidation) are absolutely issues in a home. In your case (Houston) you're actually probably better than most since you likely run the AC more (which has a dehumidifying effect)
Bryan
Bryan Pape
GIK Acoustics
Old 04-13-07, 10:55 AM   #39 (Link)
Alias: Jim
Loc: Houston, TX
User: #425
FlashJim is offline
Wayne, we might have to have a cable makin' party sometime. I'd love to see how it's done.
Jim
Houston, TX
My Subwoofer Build Page
Old 04-13-07, 03:51 PM   #40 (Link)
wig
Alias: scott
Loc: dallas tx
User: #7411
Since: Mar 2007
wig is offline
Wayne what kind of beer do I need to bring?
Old 04-13-07, 06:09 PM   #41 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
LOL - Scott, it would be hot by the time you get here! Just as well – ice tea’s my brew.
Jim, I’m working on a “How to solder DIY cables” thread that I hope to have up next month. But you’re welcome anytime for a lesson. Basically, if you can do intricate work with your hands and have a keen eye for detail, you should be able to solder.
Old 04-13-07, 06:43 PM   #42 (Link)
Loc: Lower Alabama
And he drinks about 2 gallons a day... NO.... I'm not kidding!
Wayne did a fine job on the cables he built for me... he could definitely hold a class on how to build them...
Sonnie
Old 04-16-07, 06:49 AM   #43 (Link)
Alias: Joe
Loc: CT
User: #6402
blownrx7 is offline
A while back I made a set of 15ft component cables using DH Labs Silver Sonic video cable and some decent connectors (can't remember the brand). Nowadays, I would go with the bluejeanscables.com or the premium monoprice.com video cables.
I came to the realization that there is a lot of hype with cables. I do feel a good quality connector is often the determining factor in cable performance.
Old 04-17-07, 02:03 PM   #44 (Link)
wig
Alias: scott
Loc: dallas tx
User: #7411
Since: Mar 2007
wig is offline
Wayne the Red diamond ice tea is the best.or maybe a long island. WIG
Old 05-01-07, 03:46 PM   #45 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
I made a RCA to 1/4 mono subwoofer cable from an old monster cable and Cardas parts from http://www.diycable.com/
Old 05-01-07, 05:34 PM   #46 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Well done, Jerm! Gotta love that color!
