I Need wiring help!! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss I Need wiring help!! in the Home Theater | Audio and Video forum; I Need wiring help!! I have a digital cable box (Comcast) with HDMI jack, a dvd/vhs unit with HDMI jack, and a Sharp SD-SP-10 ...
Old 12-12-06, 11:56 AM   #1 (Link)
New Member
Alias: Fred225
User: #4774
Since: Dec 2006
Fred225 is offline
I have a digital cable box (Comcast) with HDMI jack, a dvd/vhs unit with HDMI jack, and a Sharp SD-SP-10 2.1 sound system with optic inputs. If I hook the cable box to the tv with HDMI, and the dvd unit to the tv with hdmi (tv has two hdmi inputs) and connect the optic jacks on both units to the spaker system, would this work? I have a Samsung HD LCD tv and don't want to lose the picture quality. I bought the Sharp because I can't wire rear speakers in this room.
I'm new to this technology and the wiring confuses me. Help!
Old 12-12-06, 12:07 PM   #2 (Link)
Loc: Lower Alabama
Re: I Need wiring help!!
I moved this from Pro Audio to Home Theater.
I don't see any reason why your suggested wiring would not work. I assume when you state that you are going to connect the optical outputs to the speaker system that you actually mean to the receiver.
Sonnie
Old 12-12-06, 01:05 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
Assuming that the Comcast set top box and also the DVD player both output audio from their optical jack while their HDMI jack is active, then yes it would work.
I also see from a quick look at a few Samsung LCD TV's that they all seem to have 2 HDMI inputs and 1 optical output. I would presume that the audio is routed to this optical output irregardless of input selection on the TV, and as such would be a good route to connect a single optical cable from the LCD to the Sharps optical input. That way, you wouldn't have to do any switching on the Sharp.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Sub wiring - Line in 0r speaker Steve Williamson Home Audio Subwoofers 22 08-18-08 05:00 PM
Subwoofer wiring issues... aceinc DIY Subwoofers 13 10-30-06 07:57 PM
Sub Wiring Question???? moodyda Home Audio Subwoofers 5 10-01-06 04:33 PM
Retrofit wiring solutions: Wiretracks Roger Home Theater, Audio and Video News 2 05-27-06 01:20 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
