| Remotes | Cables | Accessories Which cables for sound?Discuss Which cables for sound? in the Home Theater | Audio and Video forum; Which cables for sound? I have fiber optic cables hooked up to both my hd cable box and dvd player going to my receiver ... |
| | #1 (Link) | |||
| Which cables for sound? I have fiber optic cables hooked up to both my hd cable box and dvd player going to my receiver for sound. I seem to remember reading somewhere that fiber optic is not the best cable to use for sound. What's the current opinion on this set up? | |||
| | #2 (Link) | ||||
| Re: Which cables for sound? Quote:
Can you try your DVD player with a coax and optical connection at the same time, then switch back and forth between the two? Let us know if you can hear a difference! My $0.02, and good luck. -- Otto | ||||
| | #4 (Link) | |||
| Re: Which cables for sound? As Otto says, both of these cables have both advantages and disadvantages. IMO you won't be able to hear an audible difference from either cable, the speakers used in a system will have more of an effect on the sound. | |||
| | #5 (Link) | |||
| Re: Which cables for sound? I think the biggest difference comes if you need to do a long run for sound. Optical can be run in and out of power lines no problem with no interference at all. where as the coax you would need to be careful of power lines and other electrical equipment as to avoid interference. If for short runs it really dosent matter as they will sound almost identical. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| What cables and where to buy? | Mitch G | BFD Forum | 47 | 07-21-08 04:46 PM |
| How many of you built your own cables? | Bent | Remotes | Cables | Accessories | 83 | 09-17-07 06:56 AM |
| Cables Gone Crazy | JCD | Chat Box | 8 | 11-21-06 11:30 PM |
| USB cables | Wayne A. Pflughaupt | Computers | Games | HTPC | Digital Devices | 6 | 11-08-06 03:17 PM |
| ssabripo's DIY Interconnect cables Tutorial: $200 cables for 1/10 th the cost! | ssabripo | Remotes | Cables | Accessories | 1 | 11-03-06 12:53 PM |
