| Remotes | Cables | Accessories Cable building?Discuss Cable building? in the Home Theater | Audio and Video forum; Cable building? I finally got the projector mounted on the ceiling ( http://farzanegan.org/ht/2006/05/no-ladder.html) , but now need to run cables to it.
| | #1 (Link) | |||
| Cable building? I finally got the projector mounted on the ceiling (http://farzanegan.org/ht/2006/05/no-ladder.html), but now need to run cables to it. A buddy of mine recommended building my own cables instead of buying finished ones. Has anyone done this? | |||
| | #4 (Link) | ||||
| | Re: Cable building? Quote:
Your wish is my command -- Online Soldering Tutorial. I found them to be pretty good. If it weren't for these videos, the SMD's would have never been soldered on my current project. JCD | ||||
| | #6 (Link) | |||
| Re: Cable building? Thanks JCD - I no longer have any excuses to make my own interconnects. ! As a contribution I have made up power cables, the first link is the belden cable that some cable builders use for digital components and the second in analog components: http://www.partsexpress.com/pe/pshow...53&rak=100-790 http://www.partsexpress.com/pe/pshow...number=100-577 You can also get the Marinco hospital connectors/heat shrink/techflex from PE, to make a professional job. PE used to have a tutorial on how to make your own power cables but I couldn't find it - maybe they had issues with liability. Anyway my cables are probably not as good as Shunyata but nowhere near as expensive! Guess I need a cryo chamber. | |||
| | #7 (Link) | |||
| Re: Cable building? I've used these products in the past and they work quite well. Chris' site has inspired many of us to build our own cables. http://www.bus.ucf.edu/cwhite/theater/diycable.htm Brian Bunge | |||
| | #9 (Link) | |||
| Re: Cable building? You can always go to www.bluejeanscable.com and order the custom sizes you want. I personally have not ordered from there, but everyone seems to recommend them. | |||
