Cheapest IR solution possible - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Cheapest IR solution possible in the Home Theater | Audio and Video forum; Cheapest IR solution possible Hey guys I'm looking to move my AV components into an adjacent closet from my living room. Getting tired of ...
Old 05-04-07, 03:10 PM   #1 (Link)
Alias: brandon
Loc: Murfreesboro, Tn
brandonnash's Avatar
User: #2533
Since: Sep 2006
brandonnash is online now
Hey guys
I'm looking to move my AV components into an adjacent closet from my living room. Getting tired of the kids pushing the buttons and ejecting dvds in the middle of movies. I'm looking for something very cheap that would actually work. I've got a URC-9910 RF remote now, but the RF receiver doesn't work anymore. When it did work, it would only work with every key press about 75% of the time. I'd like to have something that I can put emitters straight on the components. Someone had pointed out the powermids, but I've not heard of anyone with good experiences with these.
Thanks in advance
Old 05-04-07, 03:24 PM   #2 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is online now
Re: Cheapest IR solution possible
Cheap may not make you very happy, but I use a Xantech Hidden Link kit, and it is perfect.
Old 05-04-07, 03:31 PM   #3 (Link)
Alias: brandon
User: #2533
Since: Sep 2006
Cheap is about the only way I can work right now. Well under $100 if possible. I may end up looking for a new 9910 remote and receiver. I can upgrade the IR emitter to a splitter and put them on the components directly that way. It may work.
Old 05-04-07, 05:13 PM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
That’s pretty much a given when you put the gear in a closet. Take a look at the “IR Repeater Installation” sticky thread on this Forum for some options.
Old 02-26-08, 02:15 PM   #5 (Link)
Alias: Tom
Tommy's Avatar
User: #51
Tommy is offline
Are there any other kits that are recommended?
I looked at the Xantech Hidden Link kit recommended above but I would not need/want the receiver. I would need sensors to be put in the front wall with cat5 running to my equipment rack.
Currently I only need 4 components connected (which the above allows) but would also like to have the room to add more in the future.
I dont have a limited budget but its not something I want to spend a fortune on too.
Old 02-26-08, 09:32 PM   #6 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
I use a Terk Leapfrog system, under $30 delivered when I ordered it from Amazon a couple of years ago. IR target/RF transmitter is in the front of the room on the floor next to a speaker stand. RF receiver/IR repeater is inside an armoire at the back of the room, probably 20' or so as the crow flys. The IR repeater sits on the bottom equipment shelf and it's cabled IR bug sits loose on a middle shelf. IR repeater is powerful enough to bounce enough IR signal off the *dark* wall 4' away from the armoire and still get pretty consistent equipment response. With the doors closed (SOP) I've never had a failed command that was acknowledged by the target (flashes LED). No apparent RF issues from target to repeater and we have 802.11, cordless phones, baby monitor, multiple computers, two different cell phone carriers, etc. competing for spectrum.
-Brent
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
What solution do folks use for the dreaded BFD hum? Mitch G BFD Forum 147 07-10-08 09:47 PM
Easy-Flex DIY Painted Screen Solution Tiddler Projector Screens | DIY Screens 87 10-01-07 02:59 PM
Parent's AVR solution? allredp Home Theater Components 8 03-26-07 09:48 PM
Acoustical solution needed... Sonnie Home Audio Acoustics 48 03-20-07 10:25 PM
Long HDMI Cable Run Solution Sonnie Remotes | Cables | Accessories 1 05-25-06 04:42 AM
Mach 5 Audio
