Power consumption / conditioning - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Power consumption / conditioning in the Home Theater | Audio and Video forum; Power consumption / conditioning I've been reading a little bit lately about green homes, and reducing power consumption, etc., and was wondering how much ...
Old 05-17-07, 03:40 PM   #1 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
I've been reading a little bit lately about green homes, and reducing power consumption, etc., and was wondering how much current most gear draws when it is turned off. I know most things still trickle a small flow, and some even have clocks, status LEDs, etc. Does it make sense to have all your gear on a switchable power bar, and to turn it off when not in use? Are there power conditioners that do anything to regulate the draw when equipment is off?
Just wondering if anyone else has looked into this, or if anything good has been published. I haven't been able to find anything too reliable online, just lots of varying opinion.
Old 05-17-07, 06:48 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Power consumption / conditioning
You cannot externally regulate the power drawn by a unit in standby. It will draw what it needs. You can turn everything off, but some units will take a while to reboot and to load data.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 05-18-07, 08:28 AM   #3 (Link)
Alias: alan monro
Loc: Melbourne Australia
alan monro's Avatar
User: #465
alan monro is offline
Lightbulb Re: Power consumption / conditioning
lcaillo wrote: View Post
Owen,
Most amps cds etc on standby use up to 5 watts. In a rack of equiptment say 5 units that is like having a 25w lamp burning all the time [5x5] . At night i turn everything off. Kind regards Alan.
Old 05-23-07, 11:34 AM   #4 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
Thanks guys, maybe what I'll do is put some of the components without a clock or memory that I'd need to use on a switched power strip and turn that one off when not in use.
Old 05-23-07, 03:14 PM   #5 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is online now
A switched power strip will work, but be aware, some of your gear may still need to draw power for a time to cool. For example; many DLP/LCD TV's and projectors have fans that run for 10 - 15 sec or more after they are powered off. If you kill all power to them before they are ready you may damage them.
Mark
Old 05-23-07, 07:33 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
nova wrote: View Post
While there is little sense in recommending that one not let fans on lamp based projectors and RPTV run their cool down cycle after powering down, this is one of the most overstated fears with regard to lamp life. I have discussed the matter with numerous engineers from lamp and display makers and the consesus is clear that manufacturers are being very conservative with regard to the risk of damage in this matter, and that the primary reason to run a cool down cycle is to allow for restart sooner if the client decides to turn the set back on.
The only mechanism that has been suggested that might be cause for the need for a cool down cycle with fans that might affect lamp life is any thermal lag in the system that might allow temperature to increase for a moment. I have not been able to identify anything of the sort in any RPTV set that I have measured. It MIGHT be an issue in very compact units with very high output lamps. I have not measured any of these, and this was suggested by one of the lamp makers, though they feel the possibility is small.
The need for power in the cool down cycle has been vastly exaggerated by those who sell lots of UPS devices, and there is certainly nothing wrong with being cautious. We have sold hundreds of lamp based units, however, and rarely sell a UPS. With the relatively high number of outages in this area, one would think that if it was a significant issue we would be changing lots of lamps. In fact, we rarely see lamps that do not exceed the life expectancy of the vendor. The idea that failure to run fans in the cool down period will damage or shorten the life of a lamp is very close to the level of myth. It is a "common wisdom" that is simply mistaken.
-Joseph Joubert
Raise the bar.
Old 05-30-07, 09:40 AM   #7 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is online now
I do not disagree with you. But I think it is worth considering (allowing equipment to cool down as designed) for anyone who wants to use a power strip to turn everything off.
Mark
Old 05-30-07, 10:08 AM   #8 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Certainly, I would recommend using equipment as designed. I just would not get bent worrying about the occasional absence of a cooldown period. I would not do it as a routine method of shutting down.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Help with No Power ??????????? joey28 Manufacturers Service and Support 1 03-05-07 11:04 PM
Power On or Off......What do you do? Marks57 HiFi Audio Components 5 02-28-07 01:20 AM
Minimum Power southworth SoundSplinter 7 01-24-07 09:06 AM
Will it power my subs Lilmario215 Chat Box 3 11-02-06 10:40 PM
Power Conditioners Phil M Remotes | Cables | Accessories 10 09-05-06 07:24 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
