| Remotes | Cables | Accessories Recommendations for 12V triggered power stripDiscuss Recommendations for 12V triggered power strip in the Home Theater | Audio and Video forum; Recommendations for 12V triggered power strip Hi there,
I'm looking for an outlet or powerstrip that accepts a 12V trigger. I want to switch my class ... |
| | #1 (Link) | |||
| Recommendations for 12V triggered power strip Hi there, I'm looking for an outlet or powerstrip that accepts a 12V trigger. I want to switch my class A rear channel amp only when viewing movies -- it just runs so hot even with no input signal. So what's a cheap device that will do this for me. I can build one on my own, but I'm short on time. If there's something quick and easy out there, why should I reinvent the wheel? Thanks! -- Otto | |||
| | #2 (Link) | |||
| | Re: Recommendations for 12V triggered power strip I have the Panamax 5100, but it ain't exactly cheap. They have a 4300 model that's less and I believe it has a 12v trigger (about $130-140 on www.froogle.com). | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Looking for 12v-triggered switch | mpich | Home Theater Design and Construction | 2 | 02-06-08 10:03 PM |
| Do you think its bad to plug all this in to this power strip? | Jerm357 | Remotes | Cables | Accessories | 7 | 09-05-07 07:17 AM |
| Adapter to convert 120v to 12v | Methodical | Remotes | Cables | Accessories | 7 | 02-05-07 09:12 AM |
| 12V Trigger AC Outlet | Josuah | Home Theater Components | 2 | 01-30-07 04:39 PM |
| 12V Trigger specifications/standards | TedT | Home Theater Components | 14 | 11-04-06 07:03 PM |
