In wall component video installation question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss In wall component video installation question in the Home Theater | Audio and Video forum; In wall component video installation question New to this site, I'm sure this must be addressed somewhere but I have not been able to find it. ...
Old 08-02-07, 01:55 PM   #1 (Link)
New Member
Alias: Robert
Loc: Texas
User: #10618
Since: Aug 2007
rkweekly is offline
I need to run a component video signal from a receiver in an adjacent room to a LCD TV wall mounted approximately 30 feet away. I envisioned using wall plates with 3 RCA connecters on each end but do not know what wire to use (possibly coax or cat 5 ?) or if I need to amplify the signal.
I’m planning on running an i/r repeater set up as described in the great i/r repeater installation thread and would run the video into the same wall box the i/r receiver.
Any info or ideas greatly appreciated.
Old 08-02-07, 02:45 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: In wall component video installation question
Definitely not Cat-5. It’s not shielded, nor is it the 75-ohm –rated cable you need for video signals. RG-59 coax will work fine.
(With a question like this someone inevitably chimes in with “RG-6 – it has better bandwidth capabilities.” However, that’s only relevant with radio-frequency (RF) signals. With signal-level video, 75-ohm is what matters, not bandwidth.)
Old 08-02-07, 02:51 PM   #3 (Link)
New Member
Alias: Robert
Loc: Texas
User: #10618
Since: Aug 2007
rkweekly is offline
Thanks Wayne,
Any idea how lond the run can be without amplification?
Robert
Old 08-02-07, 03:31 PM   #4 (Link)
Alias: brucek
User: #6
brucek is online now
It depends on the frequency of the signal you're transmitting and the cable you plan to use. You can look the specific cable up and see its loses at the frequency of interest.
Thirty feet is nothing though. Don't be concerned......
Old 08-02-07, 06:46 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
rkweekly wrote: View Post
I intended to address that – sorry!
Like brucek said, using the right cable, 30 ft. is nothing, at least for what you’re talking about (component video). Just use the RG-59 and you’ll be fine.
Old 08-02-07, 07:29 PM   #6 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Try passing a video sweep through a 30 ft cable and look at the other end, terminated at 75 ohms...you might have a different view of how far you can run coax for this application. You will actually see that different cables behave quite differently. 30 ft will ususally result in just enough rolloff that you can tell the difference, but maybe not. 50 ft is pretty notieable.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 08-03-07, 09:24 AM   #7 (Link)
Alias: brucek
User: #6
Yeah, interesting. I guess cheapy cable could make a difference at these short lengths. I can't imagine any problems with decent cable (such as Belden 7710A). It has such low attenuation at HDTV bandwidths (nominal cap/ft = 16.2 pF/ft), I would think that you could easily travel 50 feet with no perceivable effect.
I guess you have to assume 1080p as worst case (~180MHz). Do they allow 1080p on component, or is the requirement for that labelled for HDMI only?
Decent cables are expensive though. A quick look at some 7710A cables yields this at $127 for 30 feet. Nice cable, nice connectors though. Yikes.
Old 08-03-07, 09:34 AM   #8 (Link)
New Member
Alias: Robert
Loc: Texas
User: #10618
Since: Aug 2007
rkweekly is offline
Thanks to everyone for the info. If I use the RG-6 or RG-59 is there a wall plate that has RCA fittings on the exterior and F style connecters on the interior or will I have to use RCA to F adapters? I have looked at some sites but have not found anything. It would seem to me that this must be a common application; maybe I am not searching correctly.
I stumbled across this product on a number of sites, basically an amplified setup using cat 5 and wondered if anyone had any experience or opinion about it.
http://globalhomeaudio.com/cat_5_drivers.html
Old 08-03-07, 09:44 AM   #9 (Link)
New Member
Alias: Robert
Loc: Texas
User: #10618
Since: Aug 2007
rkweekly is offline
Flashes of insight always seem to come after you hit the send or post button. I guessing there are RCA connectors I can use with RG-6 or RG-59 cable. I’m sort of new at this.
Old 08-03-07, 10:52 AM   #10 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Try to avoid wall plates and leave enough length to go direct. Extra connections are convenient, but less reliable.
Use compression fittings such as pro-connect or similar.
-Joseph Joubert
Raise the bar.
Old 08-03-07, 03:03 PM   #11 (Link)
Alias: AC
Loc: WICHITA, KS
ACGREEN's Avatar
User: #6917
ACGREEN is offline
I agree. I am using RG6 to distribute HDTV throughout my house. I am terminating with RCA connectors. You should leave extra cable and avoid the extra connections. I like the clean look of the wall, but it is better to go with the direct connection.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Newbie in wall RL-s 15 question. reedwesd SoundSplinter 8 08-06-07 07:06 PM
FS:Component Video Source Selector RayJr Classifieds - Video Components 0 06-28-07 05:45 PM
Video Scaler Question (Long) Pangea Video Displays and Processors 3 03-27-07 08:56 PM
Make your own component video switch HDBeat Home Theater, Audio and Video News 0 09-05-06 09:40 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
