Maximum length HDMI 1.3 cable? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Maximum length HDMI 1.3 cable? in the Home Theater | Audio and Video forum; Maximum length HDMI 1.3 cable? I am curious as to the maximum length of a HDMI ver. 1.3 cable that can still carry full 1080P ...
Old 08-04-07, 09:34 PM   #1 (Link)
Alias: MikeSp
Loc: south of Kansas City, MO
User: #2035
Since: Aug 2006
MikeSp is offline
I am curious as to the maximum length of a HDMI ver. 1.3 cable that can still carry full 1080P along with all high def audio when that audio becomes available?
Mike
Old 08-05-07, 06:24 AM   #2 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Re: Maximum length HDMI 1.3 cable?
From wikipedia:
HDMI 1.3 defined two categories of cables: Category 1 (standard or HDTV) and Category 2 (high-speed or greater than HDTV) to reduce the confusion about which cables support which video formats. Using 28 AWG, a cable of about 5 metres (~16 ft) can be manufactured easily and inexpensively to Category 1 specifications. Higher-quality construction (24 AWG, tighter construction tolerances, etc.) can reach lengths of 12 to 15 metres (~39 to 49 ft). In addition, active cables (fiber optic or dual Cat-5 cables instead of standard copper) can be used to extend HDMI to 100 metres or more. Some companies also offer amplifiers, equalizers and repeaters that can string several standard (non-active) HDMI cables together.
Hope that helps!
mech
mech
Got questions? Start a thread.
Old 08-05-07, 09:12 AM   #3 (Link)
Alias: MikeSp
User: #2035
Since: Aug 2006
MikeSp is offline
Thanks Mech -- I am embarassed because I did not look at Wikipedia...
It seems that running a 1.3 HDMI cable from a source piece to a front projector over a distance of 20 feet will require a QUALITY cable with 24 AWG -- at least it is possible as I look to the future of the HT room that I am building.
Thanks again,
Mike
Old 08-05-07, 09:18 AM   #4 (Link)
Alias: mech
mechman's Avatar
User: #6446
Check out monoprice or blue jeans cable for one.
mech
mech
Old 08-08-07, 10:12 AM   #5 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
I have nothing against MonoPrice, but the couple of times I wanted to order cables, they didn't have the length I was looking for in stock.
If that happens, and sometimes MonoPrice can't tell you when something will be available, I bought mine from RiteAV. They have 24 gauge CL2 rated HDMI cable and compared to Circuit City and Best Buy prices these are insane, $37 for a 35' premium HDMI cable.
Not to sell MonoPrice short, they have excellent prices too, and right now I see they have 22 gauge CL2 rated HDMI cables- 35' is $42.62
I've never checked Blue Jeans prices.
RiteAV says it very well though with their FAQs
RiteAV wrote:
Why are your HDMI cables so cheap?
We buy all of our cables in bulk, balancing several different suppliers to give you the best possible price. Also, you are not paying for any fancy packaging, just a quality cable.
Will my picture quality suffer compared to a more expensive cable?
No. An HDMI signal is a digital signal. As with any digital signal, you either get it or you dont. You cannot get a fuzzy picture from a bad cable, like you can with analog cables.
Saying an expensive HDMI cable will make your picture quality better is like saying an expensive USB cable will make your printer print better photos. It is just not true.
When should I spend more on a better cable?
If you are running a signal over 5 Meters, or you are running through several adapters or switches, it may be beneficial to buy a better quality cable. If an HDMI signal is run too far, you can get bit errors, which show up as sparkles in the picture. Our premium cables have larger internal wires and better shielding to preserve the signal over long distances. Amplifiers may also be necessary when going extremely long distances.
When should I pay $99.99 for a cable from the local chain store?
Never. Save your money.
I can say I have never had a single problem with any of the HDMI, Toslink, or component cables I bought from them.
Old 09-24-07, 01:20 PM   #6 (Link)
New Member
Alias: STEVE
Loc: HILLSBOROUGH, NJ
User: #11791
Since: Sep 2007
SNAP is offline
THIS FROM MONSTER CABLE:
http://www.aacdistribution.com/data/..._Confusion.pdf
Old 10-24-07, 02:28 PM   #7 (Link)
New Member
Alias: Stephane
Loc: Ottawa, Ontario, Canada
User: #6932
Riker is offline
Thanks for the info.. it's not that I find it all that confusing but rather at which technology "point" to spend my money on. ie: buy for today and the next few years or buy the absolute latest and get more future proofing..
It's Always fun to research that stuff :-)
Old 11-16-07, 12:54 AM   #8 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
alexadams77 is offline
I was wondering pretty much the same thing. I want to move my equipment rack from the front of the room to right beside me. I looked at local stores and they didn't have anything close to 20 ft and the price was through the roof. It seems that monoprice and bluejeans is the place to buy the wire lengths that I require.
TV: Panasonic TH-42PX60
Cable: Motorola w/HDTV
DVD: Panasonic DVD-S52
Receiver: Yamaha RX-V2200
Remote: Logitech Harmony 880
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
50' HDMI cable carrying 1080p Signal jagman Remotes | Cables | Accessories 5 03-15-07 10:44 AM
HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? geekwithfamily Home Theater, Audio and Video News 2 02-27-07 11:11 AM
Engadget HD Review: RazorVision HDMI video cable HDBeat Home Theater, Audio and Video News 0 10-09-06 05:26 PM
Xbox 360 HDMI cable rumor #1073 HDBeat Home Theater, Audio and Video News 0 09-05-06 05:32 PM
Long HDMI Cable Run Solution Sonnie Remotes | Cables | Accessories 1 05-25-06 04:42 AM
Mach 5 Audio
