| Remotes | Cables | Accessories Silver cables vs Copper cables!!!Discuss Silver cables vs Copper cables!!! in the Home Theater | Audio and Video forum; Silver cables vs Copper cables!!! Hi everyone... Where can i buy silver cables (DIY) innterlock cables for pre/pro to amp ...Or is copper better to ... |
| | #1 (Link) | |||
| Silver cables vs Copper cables!!! Hi everyone... Where can i buy silver cables (DIY) innterlock cables for pre/pro to amp ...Or is copper better to deal with and easier to get a hold of.... obviously silver is a better conductor and it would be more money the copper cables .All i can find is copper DIY but no silver DIY...Any suggestions?? thanks berserknitro ![]() | |||
| | #5 (Link) | |||
| Re: Silver cables vs Copper cables!!! I'll play devil's advocate here: technically, silver is a better conductor than copper, but MUCH more expensive. Having said that, the audio and video you get in your theater has already traveled down bundles of copper wire of some sort (in the record, mix, effect, remaster stages). The broadcast standard for interconnects (video mostly) is a copper coax wire, so don't worry about it. Just use copper ones and pocket the savings. One other thing, I do like gold plated contacts on all my RCA jacks and plugs. It doesnt' tarnish and also has excellent conductivity. Check out www.bluejeanscable.com (no affiliation) for some good pre-made cables for really cheap prices. They basically make nicer looking version of the same cables used in broadcast and mixing studios (RG6 coax with impedance matched ends). Best of luck! | |||
| | #6 (Link) | |||
| | Re: Silver cables vs Copper cables!!! Googling came back with these supplies: Connectors: http://www.homegrownaudio.com/rca_connectors.htm http://www.thecablepro.com/cableDeta...?cID=40&cgID=1 Cable stock: http://www.silveraudio.com/newtotal2.html http://www.homegrownaudio.com/bulk_wire.htm Projects: http://diyaudioprojects.com/Power/diySilver/index.htm Regards, Wayne | |||
| | #7 (Link) | |||
| Re: Silver cables vs Copper cables!!! Silver for audio interconnects has no real benefit. If series impedance (mostly resistance at audio freqs) is a issue -- then just use larger gauge copper wire. Lowest resistance that silver provides is of benefit when the signal runs on the skin of the conductor which happens at very high frequencies, i.e. Radio Frequencies. At audio freqs the signal can use the entire conductor thickness so just make it thicker (larger gauge). And the series impedance is only an issue if the target input load impedance is very low. Audio interconnects normally see 600 ohm or higher loads. Good idea to have very thick gauge for speaker interconnects with their low impedances. Now silver plated antennas with silver plated coax cable & connections are a great idea. ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| What cables and where to buy? | Mitch G | BFD Forum | 48 | 08-31-08 07:33 PM |
| How many of you built your own cables? | Bent | Remotes | Cables | Accessories | 83 | 09-17-07 06:56 AM |
| Which cables for sound? | SteveB | Remotes | Cables | Accessories | 4 | 01-24-07 11:13 PM |
| Cables Gone Crazy | JCD | Chat Box | 8 | 11-21-06 11:30 PM |
| ssabripo's DIY Interconnect cables Tutorial: $200 cables for 1/10 th the cost! | ssabripo | Remotes | Cables | Accessories | 1 | 11-03-06 12:53 PM |
