Wireless A/V distribution and HD Antenna's - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Wireless A/V distribution and HD Antenna's in the Home Theater | Audio and Video forum; Wireless A/V distribution and HD Antenna's Are there any products out there that wirelessly distribute A/V in HD? I know there is the Terk Leapfrog for ...
Old 09-10-07, 06:11 PM   #1 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Are there any products out there that wirelessly distribute A/V in HD? I know there is the Terk Leapfrog for regular def, but didn't know if there was anything else out there for HD.
Also, what HD OTA antenna's are good out there right now? Naturally, as small a profile as possible is preferred, but I'd be willing to go with something on the bigger side.. especially if I can find something that's inexpensive.
TKoP
Old 09-10-07, 08:08 PM   #2 (Link)
Loc: Lower Alabama
Re: Wireless A/V distribution and HD Antenna's
I'm not sure on the wireless transmission, but HD antennas are basically the same as SD antennas. Being that you are in the Bay area, I'm assuming you live near most all of the network towers. In that case I would look for a UHF antenna that extends the distance you live from the furthest tower and point it in that direction... the closer towers should be fine. You might could even go with an omni-directional.
If you aren't sure exactly how far all the towers are... go to AntennaWeb.org and fill in your address. It will give you the distance and orientation of each tower.
Old 09-11-07, 03:15 PM   #3 (Link)
Alias: Michael
Loc: Chesapeake Virginia
User: #3685
Since: Nov 2006
buggers is offline
DIY HDTV Antenna
http://www.lumenlab.com/forums/index...opic=9613&st=0
I made a klone of the DB8 from this website and for $30 It works pretty good. I have never had such a good picture over the antenna and I saved about $270 to boot
Old 09-13-07, 04:47 AM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
There is also the MPX1000 HD Multipoint Extender from Avocent.
http://www.connectivity.avocent.com/...ge/mpx1000.asp
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Splitting signal from MN740 wireless adapter Instal Computers | Games | HTPC | Digital Devices 5 07-08-07 04:22 PM
Hercules Wireless iTunes Controller - PSP Replacement? geekwithfamily Home Theater, Audio and Video News 0 03-30-07 12:50 PM
AMIMON to showcase WHDI on Sanyo's wireless HD projector at CES HDBeat Home Theater, Audio and Video News 0 01-03-07 11:00 PM
Cable-Free Surround Sound: From Wireless Speakers to Hiding Speaker Wires Chris Boylan Home Theater, Audio and Video News 0 10-18-06 07:51 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
