Coax and its terminations -- help! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Equipment Reviews.
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Coax and its terminations -- help! in the Home Theater | Audio and Video forum; Coax and its terminations -- help! I need to re-organize all of the video coax cables in my house that run from my antenna to all ...
Old 09-16-07, 01:16 PM   #1 (Link)
Alias: MikeSp
Loc: south of Kansas City, MO
User: #2035
Since: Aug 2006
  MikeSp is offline
I need to re-organize all of the video coax cables in my house that run from my antenna to all of my TVs and just want to start over from scratch with twin shield RG6 coax.
Are all RG6's the same diameter so that if I purchased one quality compression tool, it and the compression F fittings would work with all coaxes -- same question for the stripping tool that would do all three cuts at the same time. [Seems to me that I read somewhere that Canare is a different diameter and requires different tools than Belden and the rest of the quality RG6's]
What are some recommendations for high quality RG6 twin shield coax along with recommendations of brands of compression F connector fittings and compression tools & stripping tools to fit those connectors and that coax?
I would like to use a distribution amp from which 6 coax runs would originate -- recommendations for a good distribution amp for a 1 into 6 capability for HDTV?
I also need to cut into the Comcast coax cable for broadband and the Comcast cable for TV and split off connections for my home theater (those two cables run right past my AV closet) and wonder if there are standards such that the tools for adding compression F connectors to the new coax that I run would also work with the Comcast cable TV coax.
In researching this subject, I have found recommendations for Canare LV-77S, Belden 1694A and my dealer carries Tributaries coax & compression F connectors which they use in custom installs.
Thoughts/opinions regarding the best coax and matching connectors and tools along with online sources would be very much appreciated. (Some online dealers in their Sites make it difficult to discern whether or not the various crimping tools that they sell are designed for the various compression connectors that they sell).
Mike
Old 09-16-07, 05:11 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Coax and its terminations -- help!
Unless you happen to live next door to a broadcast tower, you don’t need quadshield.
It’s supposed to be a universal standard. Some of the Canare stuff you’re talking about I think is proprietary for their 75-ohm RCA connectors, which you won’t be using for this. Just make sure whatever coax you go with doesn’t have a note along the lines of “For use only with our xxx connectors” or something like that, and you should be okay.
Parts Express carries all that stuff. Maybe someone will come along here who’s a connoisseur of compression F-connectors, but if not, just avoid the bottom-of-the-line stuff and you’ll be fine.
Again, you should be fine with whatever you’re buying. I haven’t heard anything to the effect that coax was redesigned when they switched from crimp-on F-connectors to compression. It’s still the same cable.
The Canare is an RG-59. You won’t want to use that for your cable TV or broadband. As far as the Tributaries goes, I can’t find anything on it. Don’t be suckered into getting anything that’s supposedly hi-end, videophile etc. for this, as it’s only RF you’re dealing with, not signal-level.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Digital coax for sub cable jc2020 Remotes | Cables | Accessories 3 05-20-07 10:07 AM
Which cable run... coax or speaker? Sonnie Remotes | Cables | Accessories 34 03-02-07 03:38 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
