Cable adapter advice needed - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Cable adapter advice needed in the Home Theater | Audio and Video forum; Cable adapter advice needed I have an Optoma EP716 projector with VGA and S-video ports (here's what the spec sheet says: (Dual D-Sub 15, ...
Old 10-08-07, 05:36 AM   #1 (Link)
New Member
Alias: Laneman
Loc: Texas
User: #12213
Since: Oct 2007
Laneman is offline
I have an Optoma EP716 projector with VGA and S-video ports (here's what the spec sheet says: (Dual D-Sub 15, VGA for Monitor Loop Through, S-Video, Composite Video, Audio Minijack, RS-232
). I'd like to use component video or even HDMI from my DVD player to the projector. I noticed they sell adapters- is this all I need, or do I need the converter boxes that convert VGA/component signals.
Lastly, please recommend DVD player features I should look for when buying. I am using an Onkyo surround sound system in the setup.
Old 10-08-07, 09:10 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Cable adapter advice needed
You will need a component to vga adaptor to connect component to your projector. Page 9 of the manual shows the component connection.
http://marketing.optomausa.com/PDFs/...716_Manual.pdf
HDMI is another matter. You will need a convertor box to convert the HDMI digital to VGA analog. Look to spend $150 to $200. Not worth the expense in my opinion.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Advice Needed For A Used 5.1 Preamp buggers Home Theater Components 9 10-15-07 03:32 PM
Definitive Technology Bipolar selection advice needed! The sound guy Home Audio Speakers 1 08-13-07 01:32 PM
1st attempt at roomeq for sub advice needed. shawn REW Forum 20 04-25-07 08:29 PM
HDMi (dvd player) to reciever advice needed gvw System Setup and Connection 2 02-18-07 10:11 AM
Good Sub Cable w/Cheap Y-Cable... Lose Quality? baniels Remotes | Cables | Accessories 4 12-07-06 10:22 AM
Mach 5 Audio
