HD antenna help!! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
HD antenna help!!
Discuss HD antenna help!! in the Home Theater | Audio and Video forum; HD antenna help!! Ok so I have a Samsung LNS3241DX/XAA 32 inch LCD HDTV with built in ASTC tuner. I just bought a ...
Old 09-24-07, 09:59 PM   #1 (Link)
New Member
Alias: Nick Johnson
User: #11484
Since: Sep 2007
Nicktx27 is offline
HD antenna help!!
Ok so I have a Samsung LNS3241DX/XAA 32 inch LCD HDTV with built in ASTC tuner. I just bought a HD antenna from radio shack. Now maybe I'm an idiot but I can't get a signal and i don't mean just HD signal i mean i can't even get a fuzzy picture like when i used to use bunny ears with my old SD tv. Can someone help me? Please instruct me on the proper way to program my tv before i empty a bunch of 45 rounds into it. I have all the cords connected correctly and i can't figure out what I'm doing wrong. HHHEEEELLPPPP!!!!
Old 09-24-07, 10:08 PM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: HD antenna help!!
First off, not all the antennas are created equal, especially at Radio Shack. Some of their antennas are made by Terk, which can be a **** shoot in terms of what is quality engineering and what is overpriced marketing.
Let's assume you got a good one (should get UHF signals on analog TV). Other reasons to not get HDTV signals properly:
Multipath: are you near tall buildings or the outskirts of an urban/semi-urban environment? Multipath is tough to handle. When I first got HDTV I had a radio shack double bowtie (they discontinued it, but that was 7 years ago, so it might be back). I also lived right outside D.C. and got terrible multipath from the nearby buildings in Arlington. I had to position the antenna PERFECTLY to get a signal. There were little tape X's on my TV for the different channels (not all were on the same antenna then). Frustrating to say the least.
Signal Strength: if your TV has a signal strength meter for the digital channels, give us some numbers. It should be under setup or troubleshooting, or antenna info. It will be a number between 1 and 100. You'll need steady over 60 to get anything. 80's and 90's are the best. If small changes in the antenna result in big swings in signal strength, it's most likely multipath. Otherwise, small changes should show it going up or down until you get it to a peak.
I've gotta run now, so hopefully this will get you started. Also check out antennaweb.org -- they have an antenna finder tool that will let you know where the transmitters are in your area relative to your address and what antenna types are best. Post the results here and people can cue you in on installation tips and whether you have the correct antenna for your application.
Good luck!
--A
Old 09-24-07, 10:14 PM   #3 (Link)
New Member
Alias: Nick Johnson
User: #11484
Since: Sep 2007
Nicktx27 is offline
Thanks for the response. Yeah thats the other thing i have a signal strength meter however it doesn't even register it stays greyed out so i was thinking maybe i had to set something to make it receive HD signals but i don't know. I just feel like an idiot. I live in a small town and the stations are said to only be about 20 miles away 50 at the most. Not really in a rural area I'm like 5 min from downtown.
Old 09-25-07, 02:28 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Nicktx27 wrote: View Post
... thats the other thing i have a signal strength meter however it doesn't even register it stays greyed out so i was thinking maybe i had to set something to make it receive HD signals but i don't know. I just feel like an idiot. I live in a small town and the stations are said to only be about 20 miles away 50 at the most. Not really in a rural area I'm like 5 min from downtown.
Are you sure you're pointing the antenna in the right direction and with the correct side??? .... when I was installing my old antenna (I got it at Radio Shack too, 7-8 years ago) I was pointing the narrow side to the TV towers, image was not good ... then I found online the manual and it said that I have to point the wider side to the towers ... I did, and image has been great since.
Double check or triple check all connections in the antenna, TV, spliters, etc. ... maybe is just a loose connection.
Like Antonny said, go to www.antennaweb.org and see what they recommend for your area ... if you have an old antenna, you can try that one too, you don't really need a new antenna to get HD ...
Old 10-24-07, 09:29 AM   #5 (Link)
New Member
Alias: Brad
Loc: Torrance, CA
User: #2491
Since: Sep 2006
bhorstkotte is offline
Late reply, but just in case - some TVs have a switch that determines whether the antenna input is being used for a cable TV input or an OTA antenna - make sure you have it in the right position.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
