Is there a difference between clean power supplies. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Is there a difference between clean power supplies. in the Home Theater | Audio and Video forum; Is there a difference between clean power supplies. I would like to hear if there is any diference between makers or types of clean power supplies for home ...
Old 10-27-07, 04:20 PM   #1 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
I would like to hear if there is any diference between makers or types of clean power supplies for home theater equipment. I read it can possibly improve audio and video signals. Is that correct?
Old 10-27-07, 04:39 PM   #2 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
toecheese is offline
Re: Is there a difference between clean power supplies.
I'm a little confused- what kind of power supplies are you talking about? Typically the term is used for PC power supplies, but I guess it could be applied to UPS devices or power conditioners. Hard to say because of where you posted this topic.
Old 10-27-07, 05:50 PM   #3 (Link)
Loc: Lower Alabama
What particular power supplies are you considering?
Old 10-27-07, 06:30 PM   #4 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
I will be honest. I know little to nothing about them. I have seen some options at Costco that look like a surge protector. I have also seen some by monster that look similar. However, the other day I ran across some by monster that look like a stereo componet. Not sure if it is the same thing only in a fancy package.
Old 10-27-07, 06:35 PM   #5 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
FJ,
Leonard has a thread down the page called Surge Suppressors. It's a good read and I'd follow Leonard's advice! He knows what he's talking about.
http://www.hometheatershack.com/foru...ppressors.html
mech
mech
Got questions? Start a thread.
Old 10-28-07, 12:47 AM   #6 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Thanks I will check it out.
Old 10-28-07, 03:55 PM   #7 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
I am flattered, mech.
There are certainly big differences in the ability to create a clean waveform in regenerative systems, and the ability to filter in filter based systems. Most are effective at reducing line noise to some degree. The effect on video and audio quality, however, are another matter. Power supplies for video equipment will generally NOT pass low level line noise to the video circuitry at all. The power supplies in the equipment almost always are more noisy themselve than line noise. Noise picked up on grounds and from other equioment may be a factor, but rarely IME are you going to improve video with a line conditioner or filter. Some balanced power systems may improve performance, but you have to be very careful about maintaining ground integrity, particularly with incoming lines such as sat and cable systems.
My money is on good system grounding and a good cheap surge suppressor like those discussed in the SS chalenge thread that I started.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 10-28-07, 11:48 PM   #8 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
I love this site. Thanks for the info. My main purpose for wanting to know more about this is to protect and maybe improve the quality of video and audio for home theater. Your thread does provide lots of information.
I am glad I found this site.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Do "High End" Power Cables Make a Difference ? Marks57 Remotes | Cables | Accessories 36 09-09-07 06:00 PM
Anybody need a cheap Art Clean Box? Jerm357 Classifieds - Equalization and Calibration Equipment 5 08-26-07 11:14 AM
Clean Projector lens safely????? alan monro Home Theater Projectors 1 06-16-07 08:26 PM
Popcorn Machines, Supplies and Accessories Sonnie Home Theater Seating and Accessories 0 09-12-06 03:07 PM
Group Buy: Popcorn Machines, Supplies and Accessories Sonnie Specials and Group Buys 0 09-12-06 02:47 PM
Mach 5 Audio
