Im looking for an Affordable Multi Remote. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Im looking for an Affordable Multi Remote. in the Home Theater | Audio and Video forum; Im looking for an Affordable Multi Remote. I like the idea of the touch screen remote controls, but it seams like a huge price to pay just ...
Old 10-27-07, 03:43 PM   #1 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
I like the idea of the touch screen remote controls, but it seams like a huge price to pay just so I don't need to pick up a few different remotes or use the TV remote to operate limited features of the other components.
Does anyone know where I can get a good knock off of an outstanding remote.
Old 10-28-07, 08:58 AM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: Im looking for an Affordable Multi Remote.
I don't know of any knockoff remotes. However, Universal (as I understand it) and Harmony both have excellent offerings. You will have to pay for them, of course.
What's your budget?
-- Otto
Old 10-29-07, 12:09 AM   #3 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
I guess I depends on how much bling it has. I would like to stay below 200.
Old 10-29-07, 10:04 AM   #4 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
I think you can get the Harmony 880 for < $200, and the 890 for ~$250.
I use the 890 and enjoy it very much. It has a few quirks, but works extremely well.
-- Otto
Old 10-29-07, 10:22 AM   #5 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
I love my Harmony.
Old 10-29-07, 08:28 PM   #6 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
A question about the harmony remotes: How good are they at controling all the intricate menu options and setup details on recievers? How easy is it to change the layout? From what I gather, it's very macro-oriented, something I really dont need, would you agree with that? Finally, is it possible to assign multiple pages of buttins in order to fit all the original ones on the remote(for exaple" Reciever Basic, Reciever Advanced)?
Ive tried a couple and always have prefered to use my reciever's remote, but since i lost the God Blessed thing, I find myself in a market ive never researched.
Old 10-29-07, 08:44 PM   #7 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
Hi there Randy,
Most of the stuff on my preamps setup menus are usually based on the left-right-up-down and enter buttons. The Harmony will easily do that. Of course, the harmony will be able to do all existing buttons on the remote, and perhaps some that aren't on the remote. When you go to the Harmony site and tell it what device you are using, it will automatically "know" all the codes for all buttons (and then some, perhaps). You don't have to point the original remote at the Harmony in order for it to learn the existing buttons. However, in the rare event that the site does not know the device, you certainly can point the remotes together to learn the codes.
It's rather easy to change the layout. It's all done through a web-based GUI that's somewhat intuitive. I used to think it was very goofy, but they've fixed it based on user feedback. I find their willingness to change things and fix things to be very good. Anyway, for each "device" and for each "activity" you have set up, all your entries are there in the GUI. You can change them however you wish. I do wish it was a little more "drag and drop" but it's not. I give the site a good "B" grade.
As to it being macro-oriented -- it can be if you wish it, but it doesn't have to be. Each "activity" (e.g., "watch Dish" or "listen to CDs") will execute whatever commands you need in order to setup the proper inputs, select the device, start the CD or whatever. When you select an activity, it will also populate the screen with the controls you need for that activity. For example, when I select "watch Dish," the forward and backward buttons control the Dish box, and the volume controls my preamp; the screen buttons are also programmed with more Dish stuff, as well as controls for my sub (among other things). When I choose "PC," all the Dish stuff is forgotten, and it's set up to do PC-based stuff. Very slick.
You can assign multiple pages per device or per activity. I would imagine that there's some limit, but I haven't hit it. I think the greatest number of pages I have one one device is six (but I don't think that's the limit). You can put whatever you want there. However, I don't think you can label each page individually when it's inside of a single "device" or "activity." Inside each of those, the pages will just be labeled as "1 of 4," "2 of 4" and so on. You can scroll through the pages with two dedicated buttons.
I, too, had tried several different universal remotes (not to be confused with the "Universal" remote company; just various different remotes). They all sucked for some reason or another. The "best" one I had was probably the Marantz MC2000 Mk II (something like that). It was the most flexible, but had to be programmed by pointing the original at it. It ate batteries and it weighed a ton. The Harmony is rechargable, easy to program and super flexible. I'm using the 890, which is an RF-based version of the 880. I don't have any experience with other models, but I would wholeheartedly recomment the 880 or the 890 to anyone wanting a universal remote. My wife loves it. I'll never go back to using the original remotes on a day to day basis.
Good luck!
-- Otto
Old 10-29-07, 08:58 PM   #8 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
Wow, that sounds great. I think I'm gonna go to Ultimate and grab one this week. Just to clarify, when you pick an activity, the remote presents you with the neede buttons to do that activity? Pretty sweet. I dont like macros because I always start from a different point, so If the remote automatically hits the power to my dish reciever when its already on, I have to go through turning it back on....
Anyway, that was an excellent description, thank you very much, Otto.
One more question: does the 890 include RF reciever/IR transmitters to use it to control, say a Dish reciever down stairs? The lack of an RF remote has been a major complaint since we switched from Dish Network to DirecTV.
Old 10-30-07, 04:36 AM   #9 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
I highly recommend the Universal MX350. At $150 retail, it is one of the best we have found. We have programmed hundreds of remotes for clients and overall, we like it for most applications. It has RF and IR output.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 10-30-07, 04:40 AM   #10 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
yourgrandma wrote: View Post
Yep. Any which way you want to set them up.
The macros are optional, and will only do what you tell them to. By default, it will try to turn on whatever device is used in an "activity." For example, it'll try to turn on my TV for the "Watch Dish" activity. I don't like that either, because the TV might be on and then it'll turn it off, just like you said. However, there is another option in there to "leave device on all the time" and then it won't do any on/off stuff, it just leaves the power alone.
Like I was describing earlier, the Harmony database may give you other remote codes that aren't available from your original remote. One of these that comes to mind now is discrete power buttons. So, although your remote perhaps only has a button that says "power," and which simply toggles the device on and off, the Harmony database may have discrete buttons for "on" and "off." Then, you can program some of your macros to turn a device "on" only, and then even if it's already on it won't matter if the macro runs, because it's just sending another "on" command (i.e., it won't toggle it and turn it off). I generally do that for devices that I know I'll need and that have the discrete on/off commands. I know how you feel about the on/off business, and in an effort to get around it all, I simply made an "activity" called "Power" that just has "on" and "off" commands for all devices. At the end of the day, I just go to "Power" and hit them all off. Works great.
Sure, any time. I'm not 100% expert in the Harmony, but I've been working with it for a while now. Let me know if you have any questions and I'll do my best to answer.
The 890 comes with one RF receiver/IR transmitter. I hang that little device on my wall, and it shoots the necessary IR to all devices (I use an open rack that's just sitting in my living room). You can also plug into the rear of that device more IR blinkers (included). I believe there are three or four 1/8" jacks for that purpose, and each wired IR blinker has two "heads" on it. I used these when I had some componentry that was behind the TV and which couldn't be reached by the normal IR blaster. The wires on those things are kinda long (maybe 6 feet?), and I don't know if you could run an extension cable and still have them work. I would certainly try if need be...
Now you're talking about talking to your DirecTV box that's located in the basement. You could certainly do that -- put the single RF receiver down there and use it to communicate with the DTV box. No problem. Assuming that the rest of your components are in the living room (or otherwise away from the DTV box), you can simply tell the 890 to use RF to talk with the DTV box and IR to talk with the other components (the 890 handset can shoot IR directly in addition to RF). However, you're going to lose the ability to control all your devices with the RF capability of the 890. It's not a showstopper by any means, but now that I've become accustomed to not having to point the remote at the rack, there's no going back. I use it all over the house (mostly to control volume of both "zone 1" and "zone 2").
I think there are a couple ways around this. The first thing I'd try is to connect one of the IR blinker extensions to the back of the RF receiver and try to wire that down to the basement. I'd use an extension cable if necessary (again, not sure it'll work, but I'd try). If that doesn't work, I think you can get a second RF receiver and connect that with the 890. I have zero experience with using two RF receivers, but customer service will know.
Anyway, it's been a good remote. Lots of cool features, and super flexible.
-- Otto
Old 10-30-07, 06:04 AM   #11 (Link)
Alias: Fincave
Fincave's Avatar
User: #56
Fincave is offline
I have the Harmony 885 (US model 880) and am more than happy with it. Switching between activities/macros it remembers which devices are on and vice versa, as long as you ONLY use the Harmony you should not have problems with it switching something on or off. If I have powered my receiver on with it's own remote to change settings and then I press 'Listen to cd' on the Harmony it switches the receiver off as the Harmony does not know that it is already on, pressing the 'HELP' button on the Harmony the Harmony will then ask a series of questions such as 'is the receiver on?', you then have the choice of 'yes' or 'no', press 'no' and the Harmony sends the power on signal to the receiver and then asks 'did this solve the problem?', again choose 'yes' or 'no' and you are done. I am pleased with the Harmony, it does what I need it to do and their service is first class, I had a problem with the charging cradle and so sent them email. Apparently it was a known problem, Harmony wanted my address and sent a new one to me free of charge, it took two weeks to get the replacement cradle, not bad seeing as though I live in Finland and they sent the cradle from Canada, they even provided me with a tracking number!
1995
2007
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
FS: 5 Directv Receivers / Multi-switch Sonnie Classifieds - Video Components 10 01-18-07 10:54 PM
Yamaha Multi CH - Subwoofer problem aceinc System Setup and Connection 9 11-28-06 09:26 PM
Surround the next affordable evaluation DIY! JBL-4645 General Discussion 0 11-21-06 05:21 AM
Multi-disc DVD changer nm2285 Home Theater Components 4 08-06-06 11:52 PM
Outlaw 7500 and 7700, Still Affordable Despite Price Hikes Wayde Home Theater, Audio and Video News 0 07-18-06 08:14 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179
