| Remotes | Cables | Accessories Different Wire GaugeDiscuss Different Wire Gauge in the Home Theater | Audio and Video forum; Different Wire Gauge Actually after a little bit of research I find that these work best once you cut the ends off, force ... |
| | #52 (Link) | |||
| Re: Different Wire Gauge I'd like to see you squeeze those ends into a connector!! Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) Denon AVR-2807 Receiver w/AudysseyXT LG DVD Recorder w/HDMI Direct TV DVR HD Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | |||
| | #53 (Link) | |||
| Re: Different Wire Gauge If ohmly I could keep up. "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| | #56 (Link) | ||||
| | Re: Different Wire Gauge Quote:
| | #57 (Link) | |||
| Re: Different Wire Gauge Yes, I was in a strange mood and it just happened. If I must apologize I do. But when you hold me to task, consider how these other individuals have jumped on the opportunity to "shake a buzzer" so to speak . . . . . aren't they too to be held to the same standard? We're such a fun loving group here and even though we daily handle some of the worlds most intricate and important subjects and answers, we should be allowed an unseemly outburst occassionally don't you think? ![]() | |||
| | #58 (Link) | ||||
High Speed Cable/Dial Up User - Remodeling/Designing/Building | ||||
| | #60 (Link) | |||
| Re: Different Wire Gauge Another item you might consider is the use of solid core wires, but if your minimizing cost I'm not sure where to point you for the most affordable options. I would totally agree with the posters on page one (both that longer runs demand a better shielded and thicker cable to reduce interference and resistance) and that buying brand name doesn't necessarily guarantee a great product. For example, I remember reading reviews of solid core stuff several years ago when Kimber Kable first came out with their braiding strategy where reviewers would go to Radio Shack and purchase solid core wire, braid it, and see what results arrived. turns out they didn't necessarily like it better than the high priced versions, but for the money, they were convinced it was still better than several name brand items (think Monster) selling for more. I hope this information helps your decision and good luck in your application! | |||
| Thread Tools | |
Similar Threads | ||||
| how to wire avr to amp | moneybags | Home Theater Components | 4 | 11-03-07 07:59 PM |
| Straight Wire | lcaillo | Manufacturer and Vendor Reference Information | 0 | 05-04-07 08:30 PM |
| In Wall Wire Tips? | Fatawan | Home Theater Design and Construction | 4 | 02-27-07 09:06 PM |
| Im I loosing by using 16ga. Monster xp wire | jwhite8086 | Remotes | Cables | Accessories | 2 | 02-09-07 09:57 PM |
| Pre-wire for Projectors | Tommy | Home Theater Projectors | 9 | 12-29-06 11:22 AM |
