I am challenged to find a 25' 3.5mm mono cable... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss I am challenged to find a 25' 3.5mm mono cable... in the Home Theater | Audio and Video forum; I am challenged to find a 25' 3.5mm mono cable... ... at a reasonable price. I've found one, but with shipping it's $26. That sounds a bit on the high ...
Old 11-26-07, 08:35 PM   #1 (Link)
Loc: Lower Alabama
... at a reasonable price. I've found one, but with shipping it's $26. That sounds a bit on the high side. I don't see any at monocables.com or anywhere else for that matter. Seem like there are plenty of stereo cables, but mono cables appear to be rare.
Specifically I need a 25' 3.5mm mono male to male cable to go from my preamp 12volt trigger to a Panamax unit. I could probably use a 20' mono extension with one of the 6' mono cables I have now.
Anyone got any suggestions short of making my own, which would require me shop Radio Shack and probably pay about as much as a prefab one would cost.
Old 11-26-07, 11:05 PM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: I am challenged to find a 25' 3.5mm mono cable...
And a 3-conductor stereo cable won't work?
Old 11-26-07, 11:06 PM   #3 (Link)
Loc: Lower Alabama
Nope... it won't trigger.
Old 11-27-07, 07:58 PM   #4 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
How about combining a 25' RCA cable with mono RCA->3.5mm adapters? Might even have the parts laying around from building your REQW kit.
Old 11-27-07, 11:09 PM   #5 (Link)
Loc: Lower Alabama
Yeah... I could do that, but I need a small cable to tuck underneath my baseboard. I already have a balanced cable running back there for the signal and this cable will have to go behind it... very tight quarters.
I think I may have some small cable somewhere here and I'll just cut the ends of the 6' mono cable I have here and add the wire in between. It's not like it has to be pretty or perfect since it's only carrying something like 50ma of DC.
Old 11-27-07, 11:43 PM   #6 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Sounds like it's Radioshack/soldering time.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Increasing the sense of height in a vertically challenged HT:) Tristanc1 Home Theater Design and Construction 7 12-15-07 10:55 PM
A500 bridged mono Hakka DIY Subwoofers 11 11-01-07 09:42 PM
Should Measure Be Mono? Kenryan REW Forum 4 09-19-07 09:55 AM
Is rca mono to 1/4 stereo ok??? frockc REW Forum 11 02-05-07 11:05 AM
RB1070 bridged mono?? Hakka Home Theater Components 3 09-28-06 06:08 PM
Mach 5 Audio
