| Remotes | Cables | Accessories question about power voltage (or lack their of)Discuss question about power voltage (or lack their of) in the Home Theater | Audio and Video forum; question about power voltage (or lack their of) I recently upgraded to a Belkin PF 60 power conditioner (from a Monster 2000). This has readouts of voltage used ... |
| | #1 (Link) | ||||
| question about power voltage (or lack their of) I recently upgraded to a Belkin PF 60 power conditioner (from a Monster 2000). This has readouts of voltage used and amps. I'm usually only getting on average 110 volts from the wall although it fluctuates from 108 to 113. Is this really hurting my systems overall sound and picture quality? I'm considering purchasing a Monster AVS2000 to keep it at a steady 120v. Is this necessary or more importantly will I notice a big difference if I do this? Thanks! | ||||
| | #2 (Link) | ||||
| Re: question about power voltage (or lack their of) As far as I know, Voltage fluctuations like that are pretty much normal, and manufactures know that. And things like the Monster AVS2000 will only boost voltage if it drops below a certain point; taking a guess from it's product description, it looks like it will only boost Voltage back to 120 if Mains drops below 80 Volts. Our calculations are always correct, for we are gigantic brains. | ||||
| | #3 (Link) | ||||
| Re: question about power voltage (or lack their of) The AVS 2000 adjusts continually to maintain 120 volts. If line voltage drops below 80 volts then it shuts everything off until normal voltages re appear. That said... I don't think you will notice much of a difference in sound or pic quality. 110 volts is pretty normal and usually appliances are rated for 110/120 operations. | ||||
| | #5 (Link) | |||||
| Re: question about power voltage (or lack their of) Quote:
brucek | |||||
| | #8 (Link) | ||||
| Re: question about power voltage (or lack their of) A variac is actually an electro-mechanical device, effecting a change in a.c. voltage by mechanical means, not purely via electronics. ______________________ Why I support scouting... Core values taught in Cub Scouts: Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance, Positive attitude, Resourcefulness, Respect, Responsibility. | ||||
| | #9 (Link) | ||||
| Re: question about power voltage (or lack their of) So would there be an advantage (of any degree) to having one? I mean, if it takes 85 volts from the wall and bumps it up to 120 volts, it can't be supplying the same amount of energy that would be present if there was 120 volts present at the wall, can it? ![]() Our calculations are always correct, for we are gigantic brains. | ||||
| | #10 (Link) | ||||
| Re: question about power voltage (or lack their of) Ya it can. But the chances that this will actually happen are practically nil. Also, to increase the voltage on the output side, it consumes current on the input side. So while your electronics 'see' as much energy as they need, the wall cannot provide as much so if you run at high volumes or a lot of electronics you could potentially blow a breaker sooner. If your power was really low consistently, then something like this would definitely help, but in your case I doubt you'd see/hear a difference though I'd love to hear if you did. | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| bfd output voltage | exojam | BFD Forum | 13 | 02-14-08 08:52 PM |
| power question | rfrey004 | DIY Subwoofers | 2 | 07-02-07 07:00 PM |
| Voltage stabilizer or........ | Rodny Alvarez | Remotes | Cables | Accessories | 10 | 02-26-07 07:20 PM |
| Power management - or the lack thereof... | Wayne A. Pflughaupt | Computers | Games | HTPC | Digital Devices | 9 | 12-31-06 10:04 PM |
| Voltage Stablizers... | rolyasm | Remotes | Cables | Accessories | 3 | 07-17-06 06:41 PM |
