Cable Distribution problem - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Equipment Reviews.
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Cable Distribution problem in the Home Theater | Audio and Video forum; Cable Distribution problem I have a problem. My home was built 20 years ago and the cable that goes to my main TV ...
Old 12-12-07, 02:28 AM   #1 (Link)
bax
New Member
Alias: bax
User: #14280
Since: Dec 2007
  bax is offline
I have a problem. My home was built 20 years ago and the cable that goes to my main TV is a single coax from the outside of the house and trust me when I say there is no way get an additional line to the TV. I recently got dish network and the cable that comes in my house is now connected to the dish outside. Well, now here's the problem.... I also want to get my local HD channels, but I don't have an additional line to go outside to an external HD antenna. I have tried inhome antennas, but the signal is also sketchy as people walk around the house. Is there any way I can have the HD antenna and the dish network dish on the outside of the house and connect them both through a single cable to my tv? Splitters? amplifiers? any suggestions at all?
Old 12-12-07, 08:09 AM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
  Otto is online now
Re: Cable Distribution problem
bax wrote: View Post
Hi bax, and welcome to the Shack!
I don't know if there's an easy way to do that, because I don't know the bandwidth used for each set of signals. Right off the bat, I'd say "no." I know it's an extra cost, and I know that it "may not be available in your area," but have you considered getting your locals from Dish?
I tried a similar setup as yours: Dish plus OTA for local channels. At the time, I was using a 942 receiver. It worked "OK," but the signal was weak and the channels became intermittent. Are you sure that if you mount your antenna outside that your reception will be consistent for your locals?
When Dish made locals available in my area, I took them up on it and have never looked back. I gave away my HD antenna and uninstalled the cable I'd run for it. IIRC, it's $5 per month.
If that's not an option for you (and I know you said it's not possible), is it possible that you could run a coax cable in a "creative" fashion? As you know, the second cable doesn't have to follow the first. Consider anything: up walls, down walls, through the floor, tucked under the trim, etc.
Just some thoughts....
Good luck!
-- Otto
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Future proof distribution planning kjgarrison Remotes | Cables | Accessories 15 12-21-07 08:01 PM
Distribution device? punkin System Setup and Connection 4 10-26-07 06:34 PM
Wireless A/V distribution and HD Antenna's JCD Remotes | Cables | Accessories 3 09-13-07 05:47 AM
Has anybody bought cables from Signal cable or Colbolt cable??? Jay C Huskers Remotes | Cables | Accessories 0 02-04-07 12:28 PM
Good Sub Cable w/Cheap Y-Cable... Lose Quality? baniels Remotes | Cables | Accessories 4 12-07-06 11:22 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
