Lost remote for OLD NEC - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Lost remote for OLD NEC in the Home Theater | Audio and Video forum; Lost remote for OLD NEC I have a NEC monitor that I use in the bedroom. I've had this TV at least 20 years and ...
Old 12-13-07, 12:37 AM   #1 (Link)
Alias: Steve
Loc: Atlanta, GA
SteveB's Avatar
User: #3208
Since: Oct 2006
SteveB is offline
I have a NEC monitor that I use in the bedroom. I've had this TV at least 20 years and lost the remote at some point. Does anyone know where or how I could get a remote for a TV this old?
The only thing I can think to do is get a cable box and use that for on/off and channel change but that wouldn't offer a way to change volume.
Old 12-13-07, 02:13 AM   #2 (Link)
Loc: Lower Alabama
Re: Lost remote for OLD NEC
It may be that there is a universal remote that would have the codes pre-programmed. You would have to go through the scroll process until the power shut off to find your code.
You could also try www.remotecentral.com ... you may find someone that has the IR codes that you could download into an inexpensive learning remote.
Old 12-13-07, 08:00 AM   #3 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Sonnie's on the right path. I might also Google for the TV model name and "remote control" on the off chance that you might find an original remote that way.
Also, you may contact NEC directly. I bought a Panasonic remote directly from Panasonic once, and it was identical to the broken one (admittedly, it wasn't 20 years old...)
I think that the Harmony stuff will pop up with the right IR codes; they seem to have everything. I believe they are selling one model at Costco for <$100.
-- Otto
Old 12-13-07, 08:17 PM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
It’s amazing what you can find on eBay – maybe one of these will be yours.
http://search.ebay.com/search/search...ote&category0=
Old 12-13-07, 11:24 PM   #5 (Link)
Alias: Steve
Loc: Atlanta, GA
SteveB's Avatar
User: #3208
Since: Oct 2006
SteveB is offline
Thanks guys,
I had tried most of your suggestions. There are some on e-bay that are similar to the one I need but not exactly the same button layout. Sent a message to the guy that had the most NEC remotes to see if he knew which one was the right one. I have my manual for the tv but I can't find the model number, only instructions on how to use it.
Most of the stuff on remote central is way over my head. I did go ahead and sign up there and post for help.
Thanks for all your help, I'll post if anything comes of this.
Steve
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
remote. sflamedic Remotes | Cables | Accessories 3 06-04-07 09:59 PM
Remote....help Rodny Alvarez Remotes | Cables | Accessories 2 02-25-07 11:36 AM
NEC Chip Plays Both Blu-Ray and HD-DVD Wayde Home Theater, Audio and Video News 0 10-11-06 12:10 PM
Episode 15: Oh Lord(y), We?re LOST With A Double Dip Of Grease(d) Lightnin?! Roger Movies | TV Shows | Hollywood 0 09-08-06 03:20 PM
NEC 42XR4 42" Plasma TV Roger Home Theater, Audio and Video News 0 05-31-06 01:36 AM
Mach 5 Audio
