Go Back   Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Register
Speaker wire and Cables, newbie ?
Discuss Speaker wire and Cables, newbie ? in the Home Theater | Audio and Video forum; Speaker wire and Cables, newbie ? Picking up my B&W 804S on Saturday the dealer will probably try sell me on the high priced speaker wire ...
Old 12-13-07, 02:25 PM   #1 (Link)
Alias: Tuddy
Loc: Pennsylvania
Tuddy's Avatar
User: #11994
Since: Sep 2007
Tuddy is offline
and interconnects when I go in
Seeking suggestions on well-known, reasaonably priced wire and connects
I want to get the most out of the speaks so I do not want to skimp, but
do not want to spend more than I really need to
I guess I do need to get speaker cable gauge the manual suggests, and
shielded?
Is it true the thicker & shorter the wire the better?
Thanks for any feedback
Yammie RXV 1400
Outlaw 7500
B&W 804S
Center B&W HTM4S
Surrounds B&W SCMS
Old 12-13-07, 03:17 PM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Speaker wire and Cables, newbie ?
Tuddy wrote: View Post
Great speakers. You wont be disappointed.
shielded?
Yes and no, If your speakers are in a location where the speaker wires cross power cables and such then a shielded cable many help but in most cases this simply is not necessary. As far as gauge a 12 gauge wire will be plenty.
Not really, you would be hard to find anyone who could tell you that they can hear or tell the difference between a 20' length of 14 gauge and a 5' length.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Old 12-13-07, 04:26 PM   #3 (Link)
Loc: Lower Alabama
Here's a couple of good threads you might want to glance over... Different Wire Gauge... and Speaker cables that "really" make a difference?
Old 12-13-07, 04:29 PM   #4 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
The gauge thing keeps coming up and it really comes down to your speakers and the distance of the run. 12awg might not be good enough. And yes, some expensive cables can make a difference but usually in a bad way in my opinion. Of course, there are some expensive cables that do the good thing of not affecting the electrical signal much at all.
Old 12-13-07, 04:44 PM   #5 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
12 guage wire is more than sufficient for nearly any system. Other factors can make more difference than gauge, but as you say, it may not be better. I have trouble imagining how larger than 12awg would be needed. Ironically, many of the most expensive cables DO affect the signal and it may or may not be an improvement.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 12-14-07, 07:29 AM   #6 (Link)
Alias: Tuddy
Loc: Pennsylvania
Tuddy's Avatar
User: #11994
Since: Sep 2007
Tuddy is offline
Thanks for all of the insight
And Thanks Sonnie for the links to other threads
Happy Holidays All.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Speaker cables that "really" make a difference? Sonnie Remotes | Cables | Accessories 18 11-18-07 07:38 PM
Question about CL3 Speaker wire Prices. Scuba Diver Home Theater Design and Construction 4 11-02-07 07:03 AM
Speaker wire & conduit Dain Bramaged Home Theater Design and Construction 16 10-20-07 09:21 AM
A Comprehensive Guide to Splicing Speaker Wire Wayne A. Pflughaupt Remotes | Cables | Accessories 1 08-02-07 08:24 PM
ssabripo's DIY Speaker cables Tutorial (cat5e based): Audiophile wires on the cheap! ssabripo Remotes | Cables | Accessories 3 11-03-06 03:23 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
