| Remotes | Cables | Accessories Surge Protector?Discuss Surge Protector? in the Home Theater | Audio and Video forum; Surge Protector? hi, i am looking for a new surge protector. not sure what kind i need or how stronge. this is ... |
| | #1 (Link) | |||
| hi, i am looking for a new surge protector. not sure what kind i need or how stronge. this is what i have that will be plugged into it. not sure if the one i have is doing the job right i have some static shocking going on. Thanks Onkyo HT-SR800 Home Theater Pioneer PDP-5071HD Plasma TV Toshiba HD-A30 High-Definition DVD Player Directv HD Receiver Xbox 360 Console Sub Woofer From Receiver Microsoft Xbox 360 Quick Charge Kit DAYTON DAC-OC OPTICAL TO COAXIAL CONVERTER | |||
| | #2 (Link) | |||
| Re: Surge Protector? What surge protector do you have now? What do you mean by "static shocking"? Is it a sound in your components or does your surge protector literally shock you?? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #3 (Link) | ||||
| Re: Surge Protector? Quote:
brucek | ||||
| | #4 (Link) | |||
| i bought a new surge protector like this yesterday for $99.99 Monster Cable Surge Protector - 8'. and my wife is out buying another humidifier now. we have one in the bedroom. i never noticed this static shock before i got this new receiver. but when i go over to the receiver if i have to adjust settings that i can't do with the controller i get a static shock. i don't want it to crash the receiver. hoping the humidifier will fix it | |||
| | #5 (Link) | ||||
brucek | ||||
| | #6 (Link) | |||
| Re: Surge Protector? ok, well i got this humidifier today and it has a digital read out on it. so i set it to 45% is that correct or should it be higher or lower to remove the static. thanks for the help | |||
| | #7 (Link) | ||||
brucek | ||||
| | #9 (Link) | |||
| Re: Surge Protector? If the temperature outside is above freezing 45% is a good level but as the temp. goes below 20F you must set it for 30% and if its colder than that even lower. Even in a basement condensation will appear on the walls if set too high. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Retiring Baby Boomers Fuel Two-Channel - Sales Surge in 2007 | Sonnie | Home Theater, Audio and Video News | 6 | 12-18-07 03:28 PM |
| Surge Suppressors | lcaillo | Remotes | Cables | Accessories | 88 | 10-28-07 02:32 AM |
| The Protector | Hakka | Movies | TV Shows | Hollywood | 0 | 02-05-07 05:58 PM |
| Line condition/Surge Protection | Ht4me | Remotes | Cables | Accessories | 11 | 09-28-06 08:13 AM |
