| Remotes | Cables | Accessories Where to buy balanced XLR to RCA cable?Discuss Where to buy balanced XLR to RCA cable? in the Home Theater | Audio and Video forum; Where to buy balanced XLR to RCA cable? I'm going to be sending a web-order tomorrow for the Behringer FBQ2496, however I'm completely unable to find a site ... |
| | #1 (Link) | |||
| Where to buy balanced XLR to RCA cable? I'm going to be sending a web-order tomorrow for the Behringer FBQ2496, however I'm completely unable to find a site that has the appropriate cables for connecting the receiver and subwoofer via either 1/4" TRS plugs or balanced XLR cables. Can someone who has purchased these types of cables to hook up their own Behringer please direct me to a site that has such cables? http://www.americanmusical.com/item--i-HOS-CPR201.html The above is currently what I have in my shopping cart, but I'm not convinced that they are appropriate for use with the FBQ. http://www.cablestogo.com/product.asp?cat%5Fid=2029&sku=40046 This is the closest I've found, but I'd like to think a 3' cable for this application can be purchased somewhere else for far less than $18! **EDIT** Also, is it safe to place my FBQ on the bottom shelf of an audio rack (made of wood) without mounting it as you would in a live-audio environment inside a rack? Last edited by Trekari; 01-20-08 at 06:32 PM. | |||
| | #2 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? You can easily make your own XLR to 1/4' or RCA cables just do not use pin 1 on the XLR connector pin 2 is the + and pin 3 is the -. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #3 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? Thanks for the reply - I'm not electrically skilled however, and would prefer pre-made cables. I did however find my answer in the BFD forums, but I can't delete this thread. If a mod would like to delete this thread, please feel free to do so. | |||
| | #4 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? Adapters and cheap 5' cables here: http://www.musiciansfriend.com/navig...Ns=P_Price%7C0 Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #7 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? http://www.mediacollege.com/audio/co...xlr-rca-1.html It's not hard, just tedious because of the small tabs you need to solder to. A simpler solution is to get a mono 1/4" (tip-sleeve) to rca plug adapter and then just use RCA cables. http://www.radioshack.com/product/in...entPage=search I have run BFD units both ways and they work just fine. Good luck and let us know how it turns out. | |||
| | #8 (Link) | ||||
| Re: Where to buy balanced XLR to RCA cable? Quote:
http://www.musiciansfriend.com/produ...ter?sku=339508 I'd buy them from MF on principle alone, even better if you're in the market for anything else from there. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #9 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? Since I got my installer discount at Parts Express, I'm starting to notice how much things are severely marked up by Radio Shack, Best Buy, etc. I only linked to Radio Shack because that's a place most everyone has close to them. Parts Express sells a similar parts, as does Musician's Friend. I get most of my stuff from PE but I have purchased from MF years ago and they were pretty nice to deal with. | |||
| | #11 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? It will not make any difference. What little science there is behind the metal type translates into an inaudible difference. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #12 (Link) | ||||
XLR: Pin1 Screen/Earth/Common, Pin2 Hot, Pin3 Cold. Only using Pins 2 and 3 will give you an unscreened connection, as the 'earth' connection (Pin 1) is unused. It can be useful sometimes to leave Pin 1 disconnected to avoid hum loops, but it shouldn't be considered 'standard practice'. What I do personally is to always use twin screened high quality microphone cable on anything that has an XLR at one end. Red goes to Pin 2, Black goes to Pin 3 and screen goes to Pin 1. At the other end I link black and screen if going unbalanced. This means that if I ever change the unbalanced end for a balanced connector it's easy to do so. Of course, as with all things, not everyone conforms to the XLR 'standard', and some companies use Pin 3 Hot and Pin 2 Cold. As long as your wiring is consistent in all cables though, then this won't matter, although you've now inverted the phase of the audio signal. Regards, Tony | ||||
| | #13 (Link) | ||||
Consequently, I've become a big fan of looking for "off brand" items, private manufacturers and even used equipment because of these high margins. | ||||
| | #14 (Link) | |||
| Re: Where to buy balanced XLR to RCA cable? I followed a link on AVS Forum to this PDF. The poster said most commercial cables aren't wired correctly and that putting together a cable as shown in Figure 2.1 would reduce hum and a multitude of evils. Now, if I only got this attached right ![]() | |||
| | #15 (Link) | ||||
The rest of that pdf tells you why you should go out and buy a Jensen transformer. There are many makes of line level balancing transformers out there if you want to go that route. Regards, Tony ![]() | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| DIY subwoofer cable RCA terminations ?? | MikeSp | Remotes | Cables | Accessories | 6 | 02-25-08 08:15 PM |
| XLR or 1/4" to RCA Cables | Peter De Smidt | BFD Forum | 7 | 01-02-07 02:27 PM |
| My Custom DIY XLR to RCA cables | Owen Bartley | BFD Forum | 13 | 10-27-06 08:52 AM |
| Question on building an RCA to 1/4 inch cable for the BFD? | Greybeard191 | BFD Forum | 2 | 08-30-06 08:30 PM |
