Making up cables - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Making up cables
Discuss Making up cables in the Home Theater | Audio and Video forum; Making up cables Hi When making up cables, rca and xlr is it advisable to make them up as short as possible ?...
Old 01-21-08, 02:57 PM   #1 (Link)
Alias: Robin Hood
Loc: Sherwood Forest
User: #11451
Since: Sep 2007
stephenb1 is offline
Making up cables
Hi
Old 01-21-08, 03:40 PM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Making up cables
You can go as long as needed I have run home made cables as far as 30' without issue. But its always advisable to only make them as long as needed to ensure the least amount of interference can be picked up by the cable as possible. XLR can be run much farther due to the better shielding.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 01-21-08, 03:54 PM   #3 (Link)
Alias: Robin Hood
User: #11451
Since: Sep 2007
Thanks
Old 01-21-08, 07:59 PM   #4 (Link)
Gold Supporter
Alias: Jean-Pierre
Loc: Beaumont, Quebec, CANADA
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
They should be not too short, not too long. Too short may cause more damages than too long because this could break the connector or causing a short. Also, they should be long enough to avoid AC cables. I you have a rack, I think the best way is to place AC cables grouped at one side (right), and audio at the other (left).
JP
Old 01-22-08, 10:42 AM   #5 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Make them a little long, but not so much that you have to loop the extra slack.
Longest run I ever made was a 40' subwoofer cable that did not pick up any hum, but careful placement of the wire did more for that than the shielding.
Also, XLR cables have good shielding, but the primary reason they are good for long runs is that the combined + to ground and - to ground signals cancel out any intereference. That's why they are the standard for pro gear, which is usually set up in an non-idea environment much farther away from the speakers, amps, stage, etc.
Having made both and RCA to XLR (unbalanced) adapter cables, I prefer crimp on RCA by far. 5 minutes versus 30 minutes for the XLRs. Undoing the braided sheath is a pain, then combining and soldering wires onto tiny tabs -- no thank you.
For rca, it's usually strip, pin crimp, set the body, then body crimp. Done. The hardest part is remembering to put things like heat shrink or boots on the cable BEFORE I crimp on the ends That's happened more than once -- DOH!
Good luck.
Old 01-22-08, 11:21 AM   #6 (Link)
Alias: Robin Hood
User: #11451
Since: Sep 2007
Hi thanks for the info,
by the way you aren't the only one to forget the boots or the screw part of the socket for that matter !
It s still so much better than paying all that money for expensive cables and have someone else make them up.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
Woodworking and cabinet making Darren DIY Speakers 16 11-02-07 09:53 AM
A/C Cables - Miova Power Cables imbeaujp Remotes | Cables | Accessories 2 10-28-07 10:25 AM
Where can I find cables for 5.1 analog inputs or SACD cables......cheap? tdamocles Remotes | Cables | Accessories 3 09-03-07 10:00 AM
Silver cables vs Copper cables!!! BerserkNitro Remotes | Cables | Accessories 6 08-23-07 03:37 PM
ssabripo's DIY Interconnect cables Tutorial: $200 cables for 1/10 th the cost! ssabripo Remotes | Cables | Accessories 1 11-03-06 12:53 PM
Mach 5 Audio
