| Remotes | Cables | Accessories Quick Monoprice HDMI question.Discuss Quick Monoprice HDMI question. in the Home Theater | Audio and Video forum; Quick Monoprice HDMI question. I need to order an HDMI cable to run from my receiver to my projector (Onkyo 805 to Optoma HD70). ... |
| | #1 (Link) | |||
| Quick Monoprice HDMI question. I need to order an HDMI cable to run from my receiver to my projector (Onkyo 805 to Optoma HD70). Do I need to use a 1.3a spec cable for my PJ? The run will be around 40-50 feet. Thanks guys. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #2 (Link) | |||
| Re: Quick Monoprice HDMI question. For a run that long, I would go with the RapidRun from ImpactAcoustics (also available from Parts Express). They have custom length HDMI cables with either a wall plate or flying lead (regular end). The trick is that they have active and passive ends. For a long run, you would have one passive end at the projector and get the active end to put by the source. This is, in effect, a signal amplifier that allows the signal to maintain strength over long runs. They recommend it for runs over 30'. Cable: http://www.partsexpress.com/pe/showd...number=183-743 Passive end (flying lead): http://www.partsexpress.com/pe/showd...number=183-745 Active end (wall plate): http://www.partsexpress.com/pe/showd...number=183-755 $250 is pricey, I know -- but it's in-wall rated, good to 1080p up to 65' long! Several sites rave about them. I saw that Monoprice has many much cheaper, but there could be two problems: 1) pulling a cable with an end on it through the wall would be difficult if not impossible. 2) HDMI is very picky about the length of the run. People who have no problems at 15' get dropouts and other problems at 25'. It's tough to say what will work in your situation. If you have a repeater/splitter with a good amp in it, a regular cable might get you the 50' no problem. But if you go that route, be prepared if you get sync problems at the projector (like no picture at all!) | |||
| | #3 (Link) | |||
| | Re: Quick Monoprice HDMI question. I read the following while reseaching cable lengths. It is not only the cable that factors into how long a cable can successfully carry an HDMI signal, the receiver chip inside the TV or projector also plays a major factor. Receiver chips that include a feature called "cable equalization" are able to compensate for weaker signals thereby extending the potential length of any cable that is used with that device. This was in reference to cables longer then 35 feet. You could find out from Optima if your projector has such a chip. | |||
| | #4 (Link) | |||
| Re: Quick Monoprice HDMI question. That's probably what the RapidRun "active" end does. I always wondered how it amplified the signal without external power. It's probably an EQ chip, because they only recommend it for the 35' and up runs. | |||
| | #5 (Link) | |||
| Re: Quick Monoprice HDMI question. Really. If this is so, I think I'll just stick to component from the receiver to the PJ. It looks good and the only problem I can see is a very light ghost to the right of really highly contrasting parts of the picture. The only Monoprice cable with an EQ or booster was 137' long. Anyone with an HD70 want to share what they use for cable to the PJ? Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #6 (Link) | |||
| Re: Quick Monoprice HDMI question. Sorry I can't be of more help. I have a 15' (whatever was cheapest from monoprice) HDMI cable pulled to my HD70. I have no idea how a 50' would work. Can't you buy an powered extender of some type if the 50' gives you trouble? | |||
| | #7 (Link) | |||
| Re: Quick Monoprice HDMI question. I guess I could, but they arent what I would call cheap and since my component cables are working fine, I don't know if the possible rewards really justify the risk of totall nonfunction and increased cost associated with rectifying such an occurance. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #8 (Link) | |||
| Re: Quick Monoprice HDMI question. Monoprice has HDMI switches with Equalizer built in starting under $50, but I agree with everyone else. If your components are fine, stick with 'em. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #9 (Link) | |||
| Re: Quick Monoprice HDMI question. I didn't even think of it. I need HDMI to upconvert DVD! Duh! I'll stick with component till I get enough info to make a good decision on this issue. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #10 (Link) | |||
| Re: Quick Monoprice HDMI question. Have you looked at Blue Jeans Cable? They are of very high quality and have great prices plus the info on there cables is top notch even though there site looks so so . There Series-1 Bonded-Pair cable excels; in there in-use testing, they have run 1080p/60 video 125 feet without degradation. Theres tons more info on there cables on there site. They come in custom lengths, built in the USA and have different classes of quality depending on your needs. I went with there Series-F HDMI cable and have been very happy with them. Check 'em out....if not for cables do it for all the information http://www.bluejeanscable.com/store/...bles/index.htm Last edited by Jerm357; 02-01-08 at 07:40 PM. | |||
| | #11 (Link) | |||
| Re: Quick Monoprice HDMI question. Thanks, Jerm, I had sort of ruled out Blue Jean because of their really expensive components, but I'll check them out for the HDMI... Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #12 (Link) | |||
| Re: Quick Monoprice HDMI question. Hi Randy, If it helps, I use a 15m (47-ish ft) Lindy HDMI cable with our IN81 projector and it's worked out great for us. We've draped it over the sofa, run it across the floor, left it curled up; it just works. It's thick but very flexible for its size, and it's reasonably priced. I see they also do a 20m cable (that's well over 60'). Regards, Tone ![]() | |||
| | #13 (Link) | |||
| Re: Quick Monoprice HDMI question. Thanks, Tone, I figured in most cases I'd be safe with that length. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #14 (Link) | ||||
| Re: Quick Monoprice HDMI question. Quote:
![]() Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | ||||
| | #16 (Link) | |||
| Re: Quick Monoprice HDMI question. Yeah, I think so far it looks like the Belden Series 1 from Blue Jeans is the best bet right now. Maybe the next one down. What I really need is to actually figure out how I'm going to run it so I can get just the right length. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #17 (Link) | |||
| Re: Quick Monoprice HDMI question. Once more...this is making me !!Being new to the game...I'm reading more and more about regular HDMI, High-speed, V1.2, 1.3a, 10.2gps, catagory 2, CL2, flat, copper, tin...etc, etc, on and on and on... Is there a sticky specifically for HDMI cables that I can't find for some reason? I know "What's the best?" is a question relative to taste but what's the overall opinion on what's the minimum to get the best quality picture and sound from an objective viewpoint? Does any of the above really matter when it comes to picture and sound quality? I surely don't want to spend $300 on a monster cable if the BJC Series-1 Belden Bonded-Pair HDMI does the same job. Brian | |||
| | #18 (Link) | |||
| Re: Quick Monoprice HDMI question. Go monoprice. HDMI 1.3, get an EQ for your HDMI if you're worried about it, but I think at 35' you'll be fine. You may be the type that gets the cable and stay up late wondering if you made the right choice. With digital, if you plug it in, and it works, and you can't see any problems, you're at 100% Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| HDMI Question and Other Help Needed | bunks10 | General Discussion | 8 | 01-14-08 06:15 PM |
| Update - More HDMI Switch Controversy - Belkin vs. Monoprice | geekwithfamily | Home Theater, Audio and Video News | 12 | 10-24-07 10:39 PM |
| quick poll | Instal | Video Displays and Processors | 4 | 10-20-07 07:49 PM |
| HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? | geekwithfamily | Home Theater, Audio and Video News | 2 | 02-27-07 11:11 AM |
| A quick hello | Danny | Welcome | Member Introduction | 1 | 05-11-06 11:54 PM |
