Different Wire Gauge - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Different Wire Gauge in the Home Theater | Audio and Video forum; Different Wire Gauge Right now I'm using 16 gauge Monster wire for my surrounds and 14 gauge for my mains/center. If I were ...
Old 11-14-07, 02:11 PM   #1 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
alexadams77 is offline
Right now I'm using 16 gauge Monster wire for my surrounds and 14 gauge for my mains/center. If I were to go to 14 gauge for the surrounds, would I notice a difference in sound? I only turn up my system about twice a month to reference levels, the rest of the time I'm listening at like -40 at best.
TV: Panasonic TH-42PX60
Cable: Motorola w/HDTV
DVD: Panasonic DVD-S52
Receiver: Yamaha RX-V2200
Remote: Logitech Harmony 880
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-14-07, 02:34 PM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Re: Different Wire Gauge
the two most important things to consider with wire gauge are power and distance.
You say you aren't running a lot of power to them, so a lower gauge is probably fine.
How long is the run to the speakers? If the wiring is 50' or more, I'd upgrade to the 14 gauge. If it's only 20' or so, 16 gauge is more than enough. If it's 100', I would even bump up to 12 gauge.
So your mileage may vary, but usually I put 14 gauge in as a minimum. It's middle of the road, allows for more power later, and is a LOT cheaper than 12 gauge. However if changing it out is a hassle, the 16 gauge is fine.
Old 11-14-07, 02:36 PM   #3 (Link)
Shack Objectivist
Alias: Andrew
Loc: College Station, TX
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
Gauge of wire only needs to be increased if you have a long run I highly doubt increasing the gauge will help at all unless you have a 50 foot or longer run. Also, next time you get speaker wire I would suggest saving some money and going monoprice or blujeancables as they both will be cheaper and perform as well as monster.
Old 11-14-07, 02:49 PM   #4 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
Changing out the wire isn't a problem at all, that's why I was just wondering. Based on the route the wire takes to my receiver, I'd say that I'm at about 50' or more.
Is there a big difference in sound with the different types of wires out there as well?
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-14-07, 03:09 PM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
alexadams77 wrote: View Post
Short answer is No,
Monster will have you believe that there is a difference but Many people who have the right equipment to test say that they do not. Your paying for a name only. As long as the copper is good quality any brand will do, even RCA.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 11-14-07, 03:19 PM   #6 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
I'm pretty sure that when I bought this speaker wire (10 years ago) I was told that it was the best stuff on the market at that time.
I think that I might upgrade my main speaker wire as well. I bought it at the same time I bought the monster wire. It's............4 or possibly 6 wires (4 pos/4 neg) intertwined/braided together. It was supposed to be this new thing out at the time that would give you a better connection. I jumped on it, but I haven't seen anything like it since and the place where I bought it from doesn't sell it anymore either.
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-14-07, 04:19 PM   #7 (Link)
Alias: Steven
Loc: lake ozarks MO
thewire's Avatar
User: #9828
Since: Jun 2007
thewire is online now
The braided wire is actually not one one the snske oils but if you are getting something besides Monster I envy you. I was restricted to local wire (or told so) and it was my only option. I planned my theater and about the time I was done planning the construction crew was ready to hang up the drywall. I guess I could have sent them home and explained to my folks why ordering the 400ft of wire online was necessary. It is my own fault I got the Monster but there were certainly many factors out there against me. I let my fellow forum members down.
Old 11-14-07, 05:27 PM   #8 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
At the levels that I listen to my HT, I don't think that I'd be able to tell the difference between the different companies, maybe the different gauges of wire, but still I don't think that I would.
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-14-07, 10:06 PM   #9 (Link)
Alias: Worm
Loc: Colorado
User: #7339
Since: Mar 2007
Big Worm is offline
If it is easy enough you could always try it yourself. That is what I would do.
Old 11-14-07, 10:17 PM   #10 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
I just really don't want to waste my money on different types of wire gauges. I think that I'm going to just do 14 or even 12 if it's feasible.
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-15-07, 02:01 AM   #11 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
12 is not very expensive. I guess it depends on if you want the fancy name on it. 200 feet of 12 is only 75.00. Thats not bad.
Old 11-15-07, 02:03 AM   #12 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
I didn't think that 12 gauge would be so cheap. I can do my entire system for that price. Where can you get the wire for that cheap?
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-15-07, 08:18 AM   #13 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Try Parts Express (they sell different brands, but the generic is just fine).
Bluejeanscable.com
Monoprice.com
I have an installer discount at PE, so obviously I buy all my stuff there, but the other two are perfectly okay.
Part Number 100-025, Dayton 12-2, 100' roll, $60 or 60 cents a foot
Part Number 100-021, Dayton 14-2, 100' roll, $45 or 45 cents a foot
Longer and shorter spools available. When I said it was much more expensive, I meant it (33% more for 12 gauge), but at shorter runs, it's not too bad. Oh, those cables listed are NOT rated for inwall -- that's a bit more.
good luck.
Old 11-15-07, 08:52 AM   #14 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
It was my first attempt, but there's a nice link in the show notes for this episode: http://realht.info/EpisodePages/EP001.html
Old 11-15-07, 09:29 AM   #15 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Scuba Diver wrote: View Post
I bought some at The Home Depot up here in Canada for $90 Thats what I have my speakers wired with.
Home theater:
Two Channel system:
My Webpage
Old 11-15-07, 10:16 AM   #16 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
I think that I'll have to check out the Home Depot. I went to Future Shop the other day and the wire was over a dollar a foot! They didn't seem to have some "low grade" cheap stuff there.
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-15-07, 10:56 AM   #17 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
As Anthony said, don't forget monoprice, the first place you should go when buying cables or wire. 100' of 12 is $37 shipped, 200' is $65, 300' is $94. Also have 14, 16, 18 if you're not looking to overkill.
Edit: Oh wait, future shop...you're in Canada. Well, monoprice may still be your best bet, I'm just not sure what the shipping $$ would be (they do ship there though).
Old 11-15-07, 11:01 AM   #18 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
As long as the wire is made in the US, it should be worth the price. If not, then you have all the other taxes, tariffs and other fun stuff added on to that. I'll look them up and see what they have to offer and see how much it would be delivered.
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-15-07, 11:54 AM   #19 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
Has anyone heard that all the speaker wire has to be the same size? Like the Mains and Center being both 12 ft (for instance) and the surrounds being both 20 ft?
I heard this when I first bought speaker wire a few years back from a local HT shop. I could understand having, for instance, LC 12 ft of wire and the RC 30 ft, but is there any logic to this?
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-15-07, 11:59 AM   #20 (Link)
Shack Objectivist
Alias: Andrew
avaserfi's Avatar
User: #9992
Since: Jul 2007
Don't worry so much about speaker wire. In the end all good speaker wire will work properly. The definition of good in this case is the appropriate gauge for distance run and it being copper! The speakers don't care if the gauges matter or not, what the brand is or anything. Just get the right gauge for the distances you have run and focus on aspects of the system that actually effect sound like acoustics, placement, speakers etc...
Old 11-15-07, 12:11 PM   #21 (Link)
Alias: brucek
User: #6
brucek is offline
Electricity travels near the speed of light in a wire (modified slightly by the wires velocity factor).
This speed is approximated to about a nanosecond a foot. So, if one speaker wire was 50 feet longer than the other, then that signal would arrive about 50 nanoseconds later than the other.
Well, this is about 1000 times less than human hearing can even begin to detect, so don't worry about the lengths of your cables and phase differences.
Old 11-15-07, 12:19 PM   #22 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
So, as always, never listen to people selling you **** at HT Stores. For the amount of ** these people tell you, I often wonder how much stuff they really do know?
Since I'm up in Canada, would it be smarter to hit up Home Depot for the wire or order the stuff from the US? I'm pretty sure it'll be around $20 or so for shipping and these misc extra charges they conjure up at the boarder.
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-15-07, 12:20 PM   #23 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Well, pull up your order on monoprice and see how much that would be. Then, call home depot and see what they sell their wire for. Then you'll have your answer.
Old 11-15-07, 12:47 PM   #24 (Link)
