Power Conditioners - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Power Conditioners
Discuss Power Conditioners in the Home Theater | Audio and Video forum; Power Conditioners Now that the Harvester thread has run its course does anyone have any comments on Power Conditioners, as opposed to ...
Old 07-12-06, 02:36 PM   #1 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
Power Conditioners
Now that the Harvester thread has run its course does anyone have any comments on Power Conditioners, as opposed to surge devices. I'm thinking along the lines of Richard Gray, PS Audio, Shunyata etc...
I have a Richard Gray 1200, but have not done an A/B for a few years. The RG devices seem to get a wide range of reviews from excellent improvements to did nothing for me. The Shunyata Hydra conditioners get consistently good reviews (NB they have a huge price increase effective Aug 1st - buy now if you need one). In addition I've seen DIY devices that try to emulate the RG/Shunyata devices
So please post your experiences here, but share your own non-fact or non-experienced opinions with yourself.
Old 07-12-06, 08:23 PM   #2 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Re: Power Conditioners
I 'll throw my $.02 in here.
Like many encounter when they have numerous pieces of equipment I had a nasty little ground loop problem that was proving difficult to cure.In my search for a good solution I found some good info on the balanced power idea championed by Equi =Tech.They claimed that by feeding components with balanced power AC line noise could be reduced by 16-20 db and the promise of totally eliminating ground loops.
This sounded like it was worth trying so I got hold of a 500va Plitron Toroidal transformer that gave me two 60volt outputs and centre tap ground. I installed it and some MOV' s for surge protection into a metal chassis with 4 duplex AC outlets on the back.The small VA rating of the xformer meant that I could only hook up my source components. My power amps run off a dedicated 20 amp circuit.
Well I can say it absolutey worked like a charm. The nasty hum from the ground loop was gone and only a faint hiss from the amps remained if my ear is placed an inch or two from my speakers.
Also the systems sound is much more consistant from day to day when previous to using the conditioner the treble on somedays would sometimes get strident and brittle then on others it was sweet and detailed sounding.Now it is mostly the later.
So I'm a believer in the balanced AC approach.
For some good reading on balanced power check out http://www.equitech.com/articles/articles.html
Old 07-13-06, 07:58 AM   #3 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
Thanks Fred, I've heard of the balanced power approach but didn't understand it - still don't completely but getting there. Looks like it works in your system, and more cost effective than the commercial route.
If you have any design plans, or links, that you can share with the technical savvy ones please feel free to post them.
As an aside my REL subwoofer was bought in Europe and I run it off a small step up transformer here in the US, REL want $750 to swap out the plate amp - they have refused to sell a replacement transformer to their authorised repairer. I looked at the Plitron website to see if I could buy a transformer directly, they have an incredible high quality range, never bought one - didn't understand it.
Old 07-13-06, 08:01 AM   #4 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
I've just seen another alternative being sold on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...ME:B:FSEL:US:1
Link to manufacturer:
http://www.powervar.com/
My logic here tells me that audiophile = more money than brains, hospital grade is the same/similar = less cost for the same device.
Am I missing something?
Old 07-13-06, 08:14 AM   #5 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
I'm on roll this morning, the caffeine has kicked in
I've just read on one of the hifi sites that another DIY fix is to just connect a choke into the power supply:
http://www.partsexpress.com/webpage....r=81&sm=1&so=1
Any comments?
Old 07-13-06, 08:48 PM   #6 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Hi Phil ,Yes balanced power did it for me mainly because I had a ground issue.Others may find that it makes little or no difference in their systems.As for design they are easy and relatively cheap to build.A while ago I did see an excellent article on the net about building a DIY unit but can't remember where it was. I will look for it and post it here if I find it.
Thats to bad REL would not allow you to purchase a new transformer.They are a high quality product and not inexpensive so you would think they would be a little more helpful.If it is a toroidal type and you knew the voltage and current rating of the REL transformer then it is quite possible a suitable replacement could be purchased from Plitron.
The chokes you show from Parts Express are the type that are usually used in the power supply of tube amps.On the transistor side of things Musical Fidelity makes several highly acclaimed amps and preamps that use chokes in their power supplies .And Nelson Pass used them in his DIY ZEN amp designs and claims large reductions in audible noise.
Old 07-15-06, 12:52 AM   #7 (Link)
Alias: Reed
Loc: Belleville, IL
reed.hannebaum's Avatar
User: #60
reed.hannebaum is offline
Old 07-15-06, 12:57 AM   #8 (Link)
Alias: Reed
Loc: Belleville, IL
User: #60
I previously posted this message under Surger Suppressors but it is also appropriate in this thread:
I have two of the ABC1200-11 units that I use for my HT system. I bought both of these units on EBAY; $201.05 & $219.95 including shipping.
I also did some research on these units before purchasing and on isolation transformers in general. A good analysis of the benefits, myths, and pitfalls of using isolation transformers can be found at http://www.blackmagic.com/ses/bruceg...solatrans.html. If properly designed, isolation transformers can provide a good degree of common mode and normal mode noise reduction. The efficacy of the Powervar unit in this regard is shown in their test results using an ANSI/IEEE specified noise pulse applied to the input.
In my application, I have the secondary neutrals connected together, the secondary ground leads connected to a cold water pipe, and my equipment load roughly divided between the two Powervar units.
Though I can make no claims about improved system performance, my intent has been that by providing clean power to my equipment I am eliminating another possible source performance degradation.
Old 09-01-06, 09:50 AM   #9 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Ayreonaut is offline
I have noticed hiss and faint hum from my speakers both from my Carvin amp and from my Denon reciever. I also have a problem with high frequency noise from the speakers when my CRT television is on.
Is a power conditioner the solution to these problems?
Do you have any budget concious recommendations?
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 09-01-06, 04:32 PM   #10 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
I would probably say that a true online UPS would most likely fix your problem. Maybe you could run the rest of your gear through the UPS and then have the TV on a normal circuit if there is no problems with it.
Old 09-05-06, 07:24 AM   #11 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
I tried a couple of power strips with line filtering from Best Buy over the weekend.
Dynex DXPC101 ($55) and Dynex PB102 ($130). Neither of those did anything.
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
