| Remotes | Cables | Accessories TV HUM!!!Discuss TV HUM!!! in the Home Theater | Audio and Video forum; TV HUM!!! Im hoping someone could assist me. I have a hum coming from my tv. Im hoping that it is coming ... |
| | #1 (Link) | |||
| TV HUM!!! Im hoping someone could assist me. I have a hum coming from my tv. Im hoping that it is coming from a grounding problem.Some days it is louder than usual. It is also audible when I turn the volume on the remote all the way down. Thanx for any assistance given. | |||
| | #2 (Link) | |||
| | Re: TV HUM!!! You might want to get over to our BFD Forum and check out the sticky thread on the “Dreaded BFD hum.” You probably have the same problem. Typically it’s caused by the cable TV feed not being properly grounded. Plenty of info there on how to correct or deal with it. Regards, Wayne | |||
| | #3 (Link) | |||
| Re: TV HUM!!! That hum might be the capacitors and/or the electron gun inside the tube. All tube TVs and sometimes other electronics will make a very high pitched whining sound. I can normally tell when my TV is on without looking at it when there is no volume and the house is quiet because of this ultra high pitch whine. It's not very loud and it's similar to ringing one might have in their ears (almost tinnitus like). Seeing that when the volume is all the way down it is probably not coming from the speakers and thus the audio section of your TV. If the humming is loud then there may be a problem with it. Is it an old TV? If it's brand new or under warranty take it back stating that it makes a humming sound. Some more specific info from you would also help (ie: brand of TV, other components you use, etc). | |||
| | #4 (Link) | |||
| Re: TV HUM!!! Hum can also be caused by having a speaker that is not magnetically shielded to close to it, also a cellphone sitting to close can also cause intermittent interference. I also know of at least one instance of a florescent light fixture on the same circuit causing noise. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #5 (Link) | |||
| Re: TV HUM!!! hello, the brand of tv is a 36" samsung, it is about 9 yrs old. I also have a denon receiver,dvd, cable,5 sp. plus subwoofer hooked up.I just ordered a ground loop isolater and a isolation transformer from parts express to see if they will make a difference. I bought the loop iso because when I hooked my computer to the rec. I got an audible hum. thanx | |||
| | #8 (Link) | |||
| Re: TV HUM!!! thanks for everyone's help.I bought a iso transformer hooked it up at various locations,nothing happened then I unplugged the tv power cord plugged it to a another outlet and the hum was gone.So Im now looking to buy new surge protectors.Maybe all the things the I have hooked up is somehow degrading the signal. Thanks again. | |||
| | #10 (Link) | |||
| Re: TV HUM!!! Because I had the tv along with other elec. plugged into a protector. I dont have enough outlets for all of the items. So I suppose when I unplugged the tv and then put it into a separate outlet and the hum was gone, that had something to do with the over used and mediocre surge protector. | |||
| | #11 (Link) | |||
| Re: TV HUM!!! Typically hum is caused by ground loops. TVs usually don't have grounding pins on them but the cable line going straight into the TV (if that's how you have it hooked up) can cause the hum. The cable box, if that the way you do it instead, could have problems. Replace it if you can. It is possible that there is a some line noise somewhere that causes that hum and a power conditioner would probably get rid of that. I doubt changing the surge strip would do anything unless the old one had some serious problems in which case it should be replaced anyway. Is the other outlet you plugged the TV into on a different circuit? | |||
| | #12 (Link) | ||||
| Re: TV HUM!!! Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Hum Help!!! | allredp | System Setup and Connection | 13 | 01-04-08 10:40 AM |
| Please help with hum in IB with BFD | howburger | BFD Forum | 23 | 12-04-07 12:18 PM |
| HT Hum | Spakman | General Discussion | 5 | 11-30-07 10:53 PM |
| Hum | alan monro | General Discussion | 17 | 06-30-07 08:41 PM |
| More Hum problems! | Adz201 | BFD Forum | 1 | 04-05-07 08:19 PM |
