| Remotes | Cables | Accessories Belkin PF60 and behavior after power lossDiscuss Belkin PF60 and behavior after power loss in the Home Theater | Audio and Video forum; Belkin PF60 and behavior after power loss After a power failure, my PF60 forgets that it should be using the DC trigger until I press the "remote" ... |
| | #1 (Link) | |||
| Belkin PF60 and behavior after power loss After a power failure, my PF60 forgets that it should be using the DC trigger until I press the "remote" button on the front of the unit. I've had correspondence with Belkin's online support -- which is, ahem, less than helpful -- and they now recommend that I return the unit for a replacement. I'm concerned that after paying for return shipping, Belkin will ship me a new unit with the same behavior. Would someone with a PF60 let me know if their unit retains the "remote" setting after a power failure? Thanks. | |||
| | #2 (Link) | |||
| Re: Belkin PF60 and behavior after power loss A power failure resets all the PF60s settings. Out of the box the remote setting is off so when a power failure occurs it is turned off. This is normal, just like the display turning back to maximum brightness after a power failure. -Andrew | |||
| Tags |
| behavior, belkin, loss, pf60, power |
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Keystoning image, Loss of quality? | tonyvdb | Home Theater Projectors | 17 | 03-21-08 06:19 PM |
| Any opinions the Belkin PF-60?? | cruzmisl | Home Theater Components | 16 | 12-11-07 10:26 PM |
| Update - More HDMI Switch Controversy - Belkin vs. Monoprice | geekwithfamily | Home Theater, Audio and Video News | 12 | 10-24-07 10:39 PM |
| Power On or Off......What do you do? | Marks57 | HiFi Audio Components | 5 | 02-28-07 01:20 AM |
| Hearing Loss | Tommy | Chat Box | 3 | 05-14-06 11:17 AM |
