Help me choose a DIY Interconnect cable - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Remotes | Cables | Accessories
Discuss Help me choose a DIY Interconnect cable in the Home Theater | Audio and Video forum; Help me choose a DIY Interconnect cable I need to make some new interconnects....I have all the tools to make and have made some Canare LV77S interconnects....based ...
Old 03-11-08, 04:10 PM   #1 (Link)
Alias: Ron
Loc: Oklahoma
User: #15279
Since: Jan 2008
  okron is offline
I need to make some new interconnects....I have all the tools to make and have made some Canare LV77S interconnects....based on Chris Wrights' instructions here:
http://white.hometheatertalk.com/diycable.htm
I'm out of that cable and looking at some posts here... http://www.hometheatershack.com/foru...0-th-cost.html ...I see recommendations for makeing IC from Belden 89259 which would mean a new die.
I've never tried anything else to compare against the LV77S has anyone else tried both? If the difference in the cable is worth it I'll get the new die but just looking for your input/direction. Also, how flexible is the Belden 89259?
Thanks
Ron
Old 03-12-08, 08:39 AM   #2 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Help me choose a DIY Interconnect cable
I have not tried the Belden. Unless you absolutely need it for in-wall use (which I'm not even sure it's rated for), I would just stick with the Canare.
Westlake Electronic seems to always have the best prices and sells by the foot. If you are looking for weird colors, PM me and I can send you some lengths. I kinda went nuts when I did my first Canare order. I ordered way too much purple, blue, and orange
But in the end, using the Canare or Belden stuff is about the belief that as long as the cable and ends are of good quality there won't be any difference in the sound or video. Thinking along those lines, there shouldn't be any difference between the Belden and the Canare.
Old 03-12-08, 09:33 AM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
I’ll echo Mike. Canare and Belden are both excellent brands and I doubt you’ll see any or hear any difference between the two. To me, the difference would be more one of practicality and aesthetics. That particular Belden cable is plenum rated and is not going to be as supple and flexible as the Canare. That makes a difference in an equipment rack, IMO.
Old 03-12-08, 09:41 AM   #4 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
  Anthony is offline
You're telling me. I got a supply of their V3-5CFB for component runs (big garden hose component cable) and the LV77S for interconnects.
The 77S makes hookups easy, the 5CFB garden hose is near impossible to bend tight, so you really have to think ahead. If I had it to do over again, I would have gotten the dies for the thinner Canare stuff. Oh well.
I love the 77S, though. Very easy to work with.
Old 03-12-08, 08:53 PM   #5 (Link)
Alias: Ron
Loc: Oklahoma
User: #15279
Since: Jan 2008
  okron is offline
Wayne and Anthony - thanks for the reply and confirmation, although the natural instinct is to try something else looking for the next 'tweek' level I really didn't think I'd hear a difference.
Anthony - you have a PM
Thanks
Ron
« Home Theater Shack > Home Theater | Audio and Video > Remotes | Cables | Accessories »
Similar Threads
DIY Cable and Cable Tools Sonnie Remotes | Cables | Accessories 5 09-23-08 05:45 PM
Product Review Part I - Tendon Premium Video Interconnect Cable rcarlton Remotes | Cables | Accessories 9 12-04-07 11:02 PM
Diy Coaxial Cable southworth Remotes | Cables | Accessories 5 03-08-07 12:43 PM
ssabripo's DIY Interconnect cables Tutorial: $200 cables for 1/10 th the cost! ssabripo Remotes | Cables | Accessories 1 11-03-06 01:53 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
