Sub/Main Integration - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Sub/Main Integration in the Subwoofer Equalization | Calibration forum; Sub/Main Integration You know you're done when you measure +6dB at the frequency where your signals intersect. +6dB from -6dB results in ...
Old 03-20-08, 07:19 AM   #26 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Sub/Main Integration
You know you're done when you measure +6dB at the frequency where your signals intersect. +6dB from -6dB results in a perfectly flat crossover transition.
Nordo wrote:
That doesn't make sense to me
Did you see this pictorial in my post above? Is the resultant signal not +6dB at the frequency where the signals intersect?
Old 03-20-08, 09:18 AM   #27 (Link)
Alias: Nordo
Loc: Noosa, Australia
User: #17467
Since: Feb 2008
Nordo is offline
brucek wrote: View Post
I understand Xovers and I understand your example graph. I just didn't understand what Mike meant by "...measure +6dB at the frequency where your signals intersect...". I thought he was saying that the combined result of the sub and main had to show a +6dB peak at the Xover. Whereas your graph correctly shows that to get a flat graph at the Xover, both signals have to be -6dB at the Xover.
Old 03-20-08, 10:08 AM   #28 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Yeah. What is meant here is that the combined signal is +6dB from the measured signal of either sub or mains at the crossover frequency.
My DIY build Status: Almost done.
My room thread
Old 03-20-08, 10:26 AM   #29 (Link)
Alias: Edward
Loc: Brampton ON, Canada
User: #8188
Since: Apr 2007
clubfoot is offline
Mike & brucek you're on a roll here, keep it coming, pictures are worth a thousand words....
Old 03-20-08, 12:25 PM   #30 (Link)
Alias: Mike Bentz
Loc: Chicago
DrWho's Avatar
User: #2782
Since: Sep 2006
DrWho is offline
atledreier wrote: View Post
Exactly.
So I dug around for a bit and found a graph that kinda illustrates what you're trying to do. This is a measurement of my Klipsch Chorus II's being powered by an active amp I'm building for school (so basically I'm making a DSP front-end to a multichannel amplifier for active bi-/tri- amping of speakers).
Green is the filtered response of the woofer, blue is the filtered response of the squawker, and then green is the filtered response of the tweeter.
Red is the final combined system response.
The minor differences between the individual and summed responses are the result of differences imparted by the smoothing filters. DO NOT use smoothing filters when dialing in the system...I only added them to make it easier to see the concept.
My DSP isn't finished yet so I wasn't able to add any PEQ. The woofer and the squawker both have rising responses around 700Hz, so it would make sense to put a PEQ on each one to tame things a bit before the crossover (not a single PEQ on the summed system response). My tweeters are also tired which is the reason for the rise in the tweeter response - I need to replace the tweeter diaphragms (not add PEQ).
Here's another measurement of the system before the tweeter diaphragms got tired. This is the same filter settings as above, but without smoothing and without time-alignment. Notice the steep notches at 700Hz and 5kHz.
I should probably post an unsmoothed example of the first chart to illustrate how the combined red response at 700Hz actually isn't the broad peak that it looks like.
Anyways, the point here is that you get +6dB from perfect acoustic summation.
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 03-20-08, 01:52 PM   #31 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Great illustration there, Mike!
Old 03-20-08, 06:49 PM   #32 (Link)
Alias: Nordo
User: #17467
Since: Feb 2008
Nordo is offline
That makes sense. That's the basis of all Xover designs, whether your integrating a sub to your mains, or whether your designing a 2-way or 3-way speaker. I've done a fair bit of Xover design for my diy speakers (6 out of 7 in my HT).
But I'm still learning how to use REW (I previously used EFT), and a bit of ambiguous advice throws me out.
It takes very little to throw me out.
Similar Threads
Mains and sub integration. Pancakes DIY Subwoofers 12 01-21-08 12:37 AM
Range and integration questions tomtuttle REW Forum 3 07-12-07 12:35 PM
MP3 Integration to main system Owen Bartley General Discussion 14 07-11-07 07:51 AM
First real measurement subs, subs+main, subs+main large frockc REW Forum 13 03-17-07 11:42 AM
CableCard fight continues: Courts uphold integration ban, NCTA seeks delay waiver Wayde Home Theater, Audio and Video News 0 08-20-06 02:38 PM
Mach 5 Audio
