| REW Forum MBP Input SelectDiscuss MBP Input Select in the Subwoofer Equalization | Calibration forum; MBP Input Select Well I figured out why I was getting erroneous readings vs the old version. For some reason REW is choosing ... |
| | #1 (Link) | |||
| MBP Input Select Well I figured out why I was getting erroneous readings vs the old version. For some reason REW is choosing the built in mic over the line input. I have the settings in REW set to Default Input and the Audio MIDI panel default set to line in as well as the line in on the sound control panel selected. Still REW is only looking at the built in mic for input. Any ideas what else I might try? Thanks! | |||
| | #2 (Link) | |||
| Re: MBP Input Select Are you running OS X 10.4? There is a bug with Apple's JRE under 10.4 that whatever input you select in System Preferences the input that is passed to Java applications is always the built-in device. That has been fixed in 10.5. | |||
| | #5 (Link) | |||
| Re: MBP Input Select Well I called Apple today and they claim the bug to be a 3rd party developer problem. I emailed Sun Java support so we'll see if they get back to me about it. I don't understand why they won't make Java 6 available for 10.4. | |||
| | #6 (Link) | ||||
| Re: MBP Input Select Quote:
How can it be a 3rd party problem that asking Apple's JRE to return the default input always returns the built-in input under 10.4, but works as it should under 10.5? | ||||
| | #7 (Link) | |||
| Re: MBP Input Select From the Java for Mac OS 10.5 release note: Radar #4985417 USB Microphones are not recognized as default input device. Description: Java Sound now returns the default input device as the first entry in an array specified by given selection criteria. Resolution: This problem is now fixed. | |||
| Thread Tools | |
Similar Threads | ||||
| No input | Tom Edward | REW Forum | 29 | 01-12-08 10:08 PM |
| Looking for Input on New System | streaker76 | Home Theater Systems | 8 | 08-24-07 06:18 AM |
| Input on new setup | Fezzy | Home Audio Speakers | 8 | 04-16-07 11:08 AM |
| What to use for input | Mopar_Mudder | REW Forum | 4 | 02-07-07 03:19 PM |
| Max Sub Input | Gizmo | BFD Forum | 2 | 12-29-06 03:01 PM |
