| REW Forum Another connection question - M-audio 410 & SPDIFDiscuss Another connection question - M-audio 410 & SPDIF in the Equalization | Calibration forum; Another connection question - M-audio 410 & SPDIF I've seen the diagram regarding connecting "R" output to processor and "R" input to RS meter. I have a m-audio ... |
Views: 861 - Replies: 8
| Another connection question - M-audio 410 & SPDIF I've seen the diagram regarding connecting "R" output to processor and "R" input to RS meter. I have a m-audio 410 sound card, so I have an rca input, but I am using the spdif out connection for all the sound from the htpc. ie. everthing is sent to the processor via my single spdif connection and the processor is doing all the channel seperation. Will REW work this way? ie. digital out to receiver and analog in from RS meter. If not, wouldn't changing to analog out on the htpc in order to do the measurment distort my results, since when it actually came down to watching a movie or listening to anything, I would only be using the digital out. | ||||
| | #2 | ||||||
| Re: Another connection question - M-audio 410 & SPDIF Quote:
brucek | ||||||
| | #3 | |||||
Seriously, I was thinking that the only kind of connection where each speaker could be measured seperately (other than 5.1/7.1 analog inputs or physically disconnecting speakers not being tested) would be a digital connection. What other options would we have (the help file in REW says that the optimal connection would be one which allows for each speaker to be isolated). As maneuen said, letting the AVR do the signal routing would seem to be ideal. Is there a sound card that has optical input/outputs? What about sound meters?Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | |||||
| | #4 | |||||
brucek | |||||
| | #5 | ||||||
| Re: Another connection question - M-audio 410 & SPDIF I guess I was referring to the following from the REW help files under 'Getting Started --> System Connections'... Quote:
Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||||
| | #6 | |||||
If you were attempting to test each speaker on its own with crossover and in its native position, then you would just have to connect each one individually as a left or right main and run the sweep. Is this something you're trying to attempt? brucek | |||||
| | #7 | ||||
| Re: Another connection question - M-audio 410 & SPDIF Thanks for the replys, it sounds like I should just use a the creative usb soundcard and my laptop rather than the htpc and m-audio. My thinking for wanting to use the htpc was to preserve the same audio chain that I actually use. I understand that I am tuning the sub to the room, but I'm not sure how much variance there is between sound card output / type of output levels and rca input vs. digital input on the receiver. suppose with the m-audio digital output I have to turn the receiver up to x in order to achieve 75 decimals. But with the creative usb sound card and rca output/input I must turn the receiver up to "x-10" to achieve the same output level. Then in reality I have tuned everything to a level that is too quiet for actual use. Do you see my reasoning, or am I overlooking something? | ||||
| | #8 | |||||
(but I'm having fun all the same). Thanks for your answers!Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | |||||
| | #9 | |||||
Once the equalization filters are set on the BFD, then it is of no matter what level you play back through your system. brucek | |||||
