Calibrating a soundcard with REW v3.29 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Calibrating a soundcard with REW v3.29 in the Subwoofer Equalization | Calibration forum; Calibrating a soundcard with REW v3.29 Hi! I have a problem when I try to calibrate my M-Audio Mobile Pre with REW (v3.29). I bypass the ...
Old 03-26-08, 12:39 PM   #1 (Link)
New Member
Alias: Cromenon
Cromenon's Avatar
User: #18772
Since: Mar 2008
Cromenon is offline
Hi!
I bypass the line in with the output I am using and this happens.
I feel a bit odd because everything's ok,
-I connect line in with the "left" (for example) output
-I select "left" on the REW
-I press "Measure Souncard Response" in the Soundcard menu
this just should not happen...
What could be the problem?
Thanks in advance.
Old 03-26-08, 01:04 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Calibrating a soundcard with REW v3.29
Tell us about the ports you're using on the M-Audio box and the terminations on the loopback cable you're using.
(you do realize that REW is now up to version 4.11?)
Old 03-26-08, 01:11 PM   #3 (Link)
New Member
Alias: Cromenon
Cromenon's Avatar
User: #18772
Since: Mar 2008
Cromenon is offline
I'm using the 1/L (left) output port and the ch2 inst/line input port.
The loopback cable is just a double-terminated jack mono cable. Pic
Old 03-26-08, 01:24 PM   #4 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Doesn't ch2 correspond to the Right input? If so you need to select the R input on REW.
Old 03-26-08, 01:25 PM   #5 (Link)
Alias: brucek
User: #6
So you're feeding the CH2 line input (which is a balanced 1/4" TRS jack) from 1/L line out (which is an unbalanced 1/4" TS jack) ?
What terminations are on the cable ends?
Similar Threads
Calibrating the Soundcard..with xenyx802 in loop? hasse_swe REW Forum 5 02-14-08 02:02 PM
Can you use REW without calibrating your soundcard? Frank_S REW Forum 1 02-07-08 02:58 PM
Soundcard Calibrating trouble Canadian_Dude REW Forum 2 01-26-08 01:03 PM
Calibrating Soundcard- Something isnt right Mattlock REW Forum 8 12-30-07 05:00 PM
REW Issue #1: Calibrating SoundCard JCD REW Forum 7 05-01-07 05:08 PM
Mach 5 Audio
