How is impulse calculated in REW? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss How is impulse calculated in REW? in the Subwoofer Equalization | Calibration forum; How is impulse calculated in REW? I was just wondering how the impulse is actually calculated in REW, is the sweep signal convoluted with it's inverse ...
Old 03-24-08, 11:45 AM   #1 (Link)
New Member
Alias: Albert
Loc: Germany
User: #15979
Since: Jan 2008
mkoijn9 is offline
I was just wondering how the impulse is actually calculated in REW, is the sweep signal convoluted with it's inverse filter? Also, when windowing an impulse reponse in REW, is just the data in the window fft'd or is the data outside the window set to zero and then the whole lot fft'd?
Thanks
Albert
Old 03-24-08, 01:38 PM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: How is impulse calculated in REW?
The impulse response is calculated by dividing the FFT of the measurement by the FFT of the sweep, which is equivalent to convolving with the sweep inverse. The FFT's of windowed data zero the region outside the window and calculate the FFT of the whole length to maintain high plotting resolution. The frequency resolution is determined by the window length, of course.
Old 03-24-08, 01:58 PM   #3 (Link)
New Member
Alias: Albert
Loc: Germany
User: #15979
Since: Jan 2008
mkoijn9 is offline
Thanks,
regards
Albert
Similar Threads
impulse response.... Hakka REW Forum 12 01-06-08 04:32 PM
what am I missing for impulse responce? neal REW Forum 2 12-17-07 09:40 AM
Odd Impulse Response mortod REW Forum 7 09-18-07 04:10 AM
REW: time sync issue for impulse response z_accoustics REW Forum 9 03-28-07 08:22 AM
What's an OK soundcard impulse response? CdnTiger REW Forum 2 03-18-07 07:43 PM
Mach 5 Audio
