New Sub...2nd try at REW - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss New Sub...2nd try at REW in the Subwoofer Equalization | Calibration forum; New Sub...2nd try at REW Gonna get the BFD from my friend...and it looks like I can keep it since he doesnt use it anymore ...
Old 04-01-08, 11:25 AM   #26 (Link)
Alias: Rafael
Loc: Orlando
User: #17740
Since: Mar 2008
rafaelsmith is offline
Re: New Sub...2nd try at REW
Gonna get the BFD from my friend...and it looks like I can keep it since he doesnt use it anymore for his band.
So off to figure out what did with those MiDi cables I had...and to figure where I am going to put the BFD....and how to renable the MiDi port on my PC =P
Then figure out how to move my PC close enough to be able to reach the BFD with the MiDI cables...which if I recall correctly are 6 feet.
Looking forward to see what the results are and if I can actually notice a difference as opposed to measuring a difference.
Appreciate all the advice thus far...really have learned alot.
Similar Threads
Should I add a 2nd sub? lexx2004 Home Audio Subwoofers 37 06-02-08 02:38 PM
2nd time around..measurements Mattlock REW Forum 69 01-10-08 04:25 AM
Can I still run the 2nd to last REW?? terry j REW Forum 5 02-26-07 07:22 PM
Norpus' 2nd IB sub norpus DIY Subwoofers - Infinite Baffle 8 10-18-06 09:55 PM
2nd generation: Toshiba HD-A2 bobgpsr High Definition | HD-DVD | Blu-ray 1 07-27-06 01:17 PM
Mach 5 Audio
