| REW Forum How to find resonant frequency using REWDiscuss How to find resonant frequency using REW in the Equalization | Calibration forum; How to find resonant frequency using REW Hi
I downloaded REW a few weeks ago and have a question. This is probably a dumb question, but I ... |
Views: 1173 - Replies: 8
| How to find resonant frequency using REW Hi I downloaded REW a few weeks ago and have a question. This is probably a dumb question, but I will ask anyway. Certain voices and stringed instruments seam to hit a resonance in my room. Probably a combination of loudspeaker issues and room mode issues. How do I use REW to identify the frequency causing the issue? Thanks for your help. | ||||
| | #2 | ||||
| Re: How to find resonant frequency using REW Since you note the problem is with voices and stringed instruments, I'm guessing what you're hearing is in the upper frequencies (i.e., above the subwoofer range). Depending on exactly where it is, it may be with the speakers themselves rather than your room. REW can tell you where the problem is; just take a full-range reading. The Radio Shack meter is only good to about 7 kHz, but the problem will more than likely be below that point. Regards, Wayne | ||||
| | #3 | ||||
| Re: How to find resonant frequency using REW If the resonant frequency is within the room REW should be able to help you find the issue, but that won't be the case with cabinet resonance. Cabinet resonance is not measurable via typical methods of measurement, but rather, in an far field anechoic situation using impulse response tones at varying angles then a waterfall plot would need be derived for cabinet resonance to show up on a plot. A more simple method would be using an accelerometer attached to various point on the cabinet and then averaging the responses. It is however fairly likely that your speakers do have resonant cabinets as most DIY and commercial speakers have fairly resonant cabinets. Andrew | ||||
| | #4 | ||||
| Re: How to find resonant frequency using REW Thanks for the reply. Question - If the resonance is heard as fairly large gain in volume during the resonance, would it most likely be the room - or can a loudspeaker enclosure have that loud of a resonance? The speakers in question are Vandersteen 3A's. I just got a pair of Klipschorn's, so I am experimenting with them also. Dan | ||||
| | #5 | |||||
| Re: How to find resonant frequency using REW Quote:
The more reverberant/resonant the room, the more audible cabinet resonances become - as is shown by the current standing perceptual research.-Chris | |||||
| | #6 | |||||
Regards, Wayne | |||||
| | #7 | ||||
| Re: How to find resonant frequency using REW Agree with Wayne on this one. Take some full range measurements with both front speakers and separate measurements (with only one speaker at a time) if you feel like it might help. Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||
| | #8 | |||||
-Chris | |||||
| | #9 | ||||
| Re: How to find resonant frequency using REW REW doesn't know cabinet resonances from your mamma's pancakes. What it will show is hot spots in response, if there are any. It's up to us to figure out what's causing them. Regards, Wayne | ||||
