REW and AVR only - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
REW and AVR only
Discuss REW and AVR only in the Subwoofer Equalization | Calibration forum; REW and AVR only In two days i'll be taking my first measurements with REW. I only have an AVR (entry level Onkyo) - ...
Old 04-01-08, 04:02 PM   #1 (Link)
Alias: Augie
Loc: San Joaquin Valley, CA
User: #17748
Since: Mar 2008
augmont is offline
REW and AVR only
In two days i'll be taking my first measurements with REW. I only have an AVR (entry level Onkyo) - no amps, pre-amp, etc. what will i be able to do once i measure my room? Perhaps i had higher expectations on ability to "tweak" my system but after reading a few posts, i'm not so sure anymore. Speakers and sub locations are pretty much fixed due to WAF.
I have Infinity Primus 360's as L/C/R, 150's for surrounds, and a Rythmik 15" sub (DS1500). I just completed the sub which is why i'm wanting to use REW.
Old 04-01-08, 04:37 PM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: REW and AVR only
If your DS1500 is driven from a sub output on your AVR then you would have the ability to put an equaliser in the path to the sub to apply some EQ to it, if your measurements showed that would be beneficial.
You could also use your measurements to
- find the best place to sit if you have some choices over seating
- see if there are strong reflections from walls or floor that are degrading the sound and could be helped by a rug or some (fairly) unobtrusive wall panels at the first reflection points
- check whether your speaker distance alignments are set correctly
- check whether your speaker levels are set correctly
- check whether your sub polarity is set correctly
- check whether your sub level is set correctly
Old 04-05-08, 09:29 AM   #3 (Link)
Alias: Augie
User: #17748
Since: Mar 2008
augmont is offline
Rythmik 15 sub
First Measurement. Please critique. the dip is at 44.4hz
Old 04-05-08, 09:42 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Please critique
Please use the standard axis we use at the Shack.
Vertical axis scale = 45dB-105dB
Horizontal axis scale = 15Hz-200Hz
Old 04-05-08, 11:51 AM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Hopefully you can try another location? This one is not working well.
I assume this is subs and mains together, since there appears to be no signal drop above 80 Hz or so? If so, make sure your mains are set to “small.”
Old 04-05-08, 11:54 AM   #6 (Link)
Alias: Augie
User: #17748
Since: Mar 2008
augmont is offline
It was only the sub. looks like i need to retest and figure something out. Where should my connection on the AVR from the soundcard should be? I used the CD input
Old 04-05-08, 12:11 PM   #7 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, CD or AUX is good....
Old 04-05-08, 12:35 PM   #8 (Link)
Alias: Augie
User: #17748
Since: Mar 2008
augmont is offline
The crossover is 80hz and speaker set to small. Is the reciever not doing it's job? On the end Freq, i set it at 200hz? should that be changed? Should I unplug my mains (i thought i did but really can't remember)?
Old 04-05-08, 01:25 PM   #9 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
augmont wrote: View Post
Well, you noted in post #6 that it was a “sub only” graph. I assume that means you did not have the receiver in the signal chain at the time. The receiver can’t “do its job” unless it’s in the signal chain... Using the CD or AUX input will put the receiver in the signal chain.
If you’re referring to the graph axis, 200 Hz is fine.
Typically recommend graphing the sub first, then adding the mains, but that’s if you’re equalizing the sub. Since you’re not doing that yet, it doesn’t matter.
Old 04-05-08, 01:58 PM   #10 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, if you want to do a sub only measure - and you should.
It's just a good idea to disconnect the mains and get a look at the sub itself through the receiver with the crossover set..
It's also a good idea (even though you're maybe not equalizing), to set the proper target crossover in REW to 80Hz also. You have yours up around 120Hz I believe (from looking at your graph). It makes no difference at this point, but it's nice to see if the sub tracks the 80Hz target line on the graph or not. It's all about gathering information. If you see that you have a perfectly tracking sub and then the sub + mains is wacky, you know where the problem lies......
Old 04-05-08, 02:15 PM   #11 (Link)
Alias: Augie
User: #17748
Since: Mar 2008
augmont is offline
Sorry, I meant that i was "attempting" to measure the sub only. I hooked up the sound card to the receiver's CD input. Your observation of no drop off after around 80hz means 1.) my mains were in the mix when "attempting" to measure only the sub, 2.) i did something wrong. I think it's both.
Question: if i retest, unplug my mains, reverify speakers are set to small and crossover 80hz on the reciever, i should get roll off at/near 80hz? If i don't, then is my problem with my sound card and/or REW settings, or bad receiver?
Old 04-05-08, 02:20 PM   #12 (Link)
Alias: Augie
User: #17748
Since: Mar 2008
augmont is offline
brucek wrote: View Post
Bruce,
in looking at my target settings, it was at 80hz. What am i not seeing or missing up?
Old 04-05-08, 03:03 PM   #13 (Link)
Alias: brucek
User: #6
brucek is offline
The latter.............
Really? OK, I'll take your word for it.
Here's what an 80Hz target looks like on my computer.
You can see I'm down -6dB at 80Hz. You're not. You're only -3dB down. Hopefully you have a slope of 24dB/octave set?
Old 04-05-08, 11:18 PM   #14 (Link)
Alias: Augie
User: #17748
Since: Mar 2008
augmont is offline
Attachment 7080
I set the slope at 12db/octave. It's probably due to my misunderstanding of the Rythmik kit i have. I order the sealed 12/bd/octave subwoofer kit since that's what they recommend we using an AVR and so i thought i needed set the graph at 12 bd/octave. sounds like the two are not related.
Old 04-06-08, 05:54 AM   #15 (Link)
Alias: brucek
User: #6
brucek is offline
The setting of the 24dB/oct slope in REW is matching it against the receivers crossover setting of its low pass filter (LPF). The standard is 24. This is the slope at which it rolls off the sub out high frequencies just as you see in the target diagram above in my previous post.
The sub itself will have its own internal LPF shut off in this case so as not to interfere with the one set in the receiver.
Similar Threads
Should I just upgrade my AVR or get an amp and AVR? E-A-G-L-E-S Home Theater Components 9 03-30-08 10:21 AM
HK avr 35 Jodean Home Theater Components 5 02-27-08 06:18 PM
Budget AVR? faigenistic Home Theater Components 5 11-08-07 11:17 PM
Hk Avr-445 chas Home Theater Components 0 03-15-07 09:22 AM
Pulsar and AVR Phil M DIY Speakers 6 07-07-06 05:02 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
