REW Forum
REW with Radio Shack ANALOG SPL meter
Discuss REW with Radio Shack ANALOG SPL meter in the Equalization | Calibration forum; REW with Radio Shack ANALOG SPL meter One quick question, when using REW with the RS Analog SPL meter what should the meter be set to? C ...
Views: 735 - Replies: 4
Old 03-31-08, 07:40 PM   #1
Alias: xboy
User: #18909
Since: Mar 2008
  xboy is offline
C weighting?
Slow Response?
dial to 80?
Old 03-31-08, 07:41 PM   #2
Alias: Canadian_Dude
Loc: Edmonton, AB
User: #15927
Since: Jan 2008
  Canadian_Dude is offline
Re: REW with Radio Shack ANALOG SPL meter
Yes, yes yes is how I did mine.
Old 04-01-08, 02:37 AM   #3
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
Yes, that's what's described in the REW documentation:
Your SPL meter's range should be set to the value normally used for speaker level calibration and must not be altered while using REW. If you are using the Radio Shack meter, select the 80dB range if you calibrate your system at 75dB (this is the standard level recommended by DolbyTM).
Set your meter to C weighting. If you are using a microphone and preamplifier for measurement, untick the C Weighted SPL Meter box in the Mic/Meter Settings.
Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha
Old 04-01-08, 06:25 PM   #4
Alias: xboy
User: #18909
Since: Mar 2008
  xboy is offline
I couldn't see in the help files mention anything about setting the meter to SLOW or FAST response; thus why I asked.
Old 04-01-08, 06:54 PM   #5
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
The slow or fast settings only affect the meter reading, not the meter output, so it doesn't really matter for REW. I've updated the help files to say to use slow, as that is easier to read.
