REW Forum
sub equalizing
Discuss sub equalizing in the Equalization | Calibration forum; sub equalizing When equalizing the sub firstly, should I make sure the mains are off so only the subwoofer will make noise?...
Views: 367 - Replies: 2
Old 03-31-08, 09:10 PM   #1
Alias: xboy
User: #18909
Since: Mar 2008
  xboy is offline
sub equalizing
Old 03-31-08, 10:22 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: sub equalizing
Yes.................
Old 04-01-08, 02:30 AM   #3
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
Re: sub equalizing
And if you use Room Eq Wizard then remember to use the subwoofer test signals, not the full range.
Look at many other threads in this forum to see how others have done it.
Good luck !
Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha
