| REW Forum REW noobieDiscuss REW noobie in the Subwoofer Equalization | Calibration forum; REW noobie So I finally got my DSP1124 BFD and have everything hooked up.
Test tones play fine, I can get some ... |
| | #1 (Link) | |||
| REW noobie So I finally got my DSP1124 BFD and have everything hooked up. Test tones play fine, I can get some sort of measurement, but I do not have a midi cable long enough to have the REW communicate with the BFD. So I have to input the filters in manually. I make one measurement, then open up the eq window to add some filters and see the expected result. But what should I do to properly get a "remeasurement" so that I can iterate over my set of filters and have a properly updated graph? Last time I tried, when I did the next measurement and I open the EQ settings, it doesn't know anything about the filters that are already in use to give these new results. How do I carry them through? ![]() | |||
| | #3 (Link) | |||||
| | Re: REW noobie Welcome to the Forum, xboy! Quote:
Alternately, you can use the RTA feature and tweak filters in real time. Regards, Wayne | |||||
| | #4 (Link) | |||
| Re: REW noobie What is RTA feaure? It might be useful if the there can be predicted responses on the second sweep taking into account an existing set of filters in use. Possible? Also, I'm not show how I can show the second sweep overlayed along the predicted result of the first measurement (when adjusting filters). | |||
| | #5 (Link) | ||||
| Re: REW noobie Quote:
The RTA feature is also described in the what's new. brucek | ||||
| | #6 (Link) | |||
| Re: REW noobie I am a noobie also with REW. Can someone post a picture of there setup so I can get an idea how its setup. Laptop, spl meter and cables needed to connect to laptop and AVR. Please that would be great. | |||
| | #7 (Link) | ||||
http://www.hometheatershack.com/room...arted.html#top Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Noobie here... | thekl0wn | Welcome | Member Introduction | 7 | 07-22-07 06:03 PM |
| Noobie with REW help with measurements | rm1759 | REW Forum | 14 | 06-07-07 05:18 PM |
