Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Automatic Soundcard Compensation with spd/if
Discuss Automatic Soundcard Compensation with spd/if in the Subwoofer Equalization | Calibration forum; Automatic Soundcard Compensation with spd/if So if I want to use the automatic soundcard compensation but my output from my soundcard is spd/if (hooked ...
Old 04-01-08, 01:02 PM   #1 (Link)
Alias: xboy
User: #18909
Since: Mar 2008
xboy is offline
So if I want to use the automatic soundcard compensation but my output from my soundcard is spd/if (hooked up to receiver), how do I do a loop back connection?
Should I connect the left preout from my receiver to the left line in? This would take into account the delay through the system, no?
Old 04-01-08, 01:25 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Automatic Soundcard Compensation with spd/if
What is the reasoning for this? REW was designed to be used with the analog line-out and line-in connections, so that you can measure and setup filters in an equalizer.
Old 04-01-08, 01:26 PM   #3 (Link)
Alias: xboy
User: #18909
Since: Mar 2008
xboy is offline
So the test tone is as clean as possible?
Old 04-01-08, 01:27 PM   #4 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
You could try it, problem is you end up compensating for whatever the response of the receiver preout is which may not match the response of the other outputs - it could have a different LF roll-off. Try looping the sub output back to the right line input and make a measurement to see how flat the sub output comes out at LF, that will show you whether or not the compensation is correct.
Old 04-01-08, 01:35 PM   #5 (Link)
Alias: xboy
User: #18909
Since: Mar 2008
xboy is offline
What about this connection method?
I have an Audigy2, and it has both PCM digital output and analog output.
So if I loopback the analog output directly into the line-in and hook up the digital out to my AMP, my measurements should be valid?
Or is it dependent that it must use analog version from the sound card?
Old 04-01-08, 02:18 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
I admit to not having a clue as to what you are attempting to do here?
Is your goal to use REW and a PC to measure your subwoofers response and suggest filters for an equalizer?
Old 04-01-08, 04:21 PM   #7 (Link)
Alias: xboy
User: #18909
Since: Mar 2008
xboy is offline
brucek wrote: View Post
Yes, just that my PC sound card has digital output and my receiver can use that..
Old 04-01-08, 04:28 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
Does your soundcard not have an analog line-out and line-in?
bruce
Old 04-01-08, 04:55 PM   #9 (Link)
Alias: xboy
User: #18909
Since: Mar 2008
xboy is offline
bruce
Yeah it does, I'll guess I'll just use that and send the analog out to the amp.
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
Automatic Calibration Irks... ShnuggMac Home Theater Components 14 12-03-07 11:21 PM
Pioneer Elite VSX-82TXS automatic MCACC calibration issues The sound guy Home Theater Components 4 08-19-07 10:01 PM
Trouble with Baffle Step Compensation Circuits BoomieMCT DIY Speakers 1 04-13-07 07:22 PM
Double Compensation Risk jeffbridges REW Forum 1 09-18-06 11:49 AM
Win a DVD of your choice... (automatic entry after 10 posts)... Sonnie Movies | TV Shows | Hollywood 0 06-01-06 02:07 AM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
Search Engine Friendly URLs by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173
