Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Question about "reference" calibration.
Discuss Question about "reference" calibration. in the Subwoofer Equalization | Calibration forum; Question about "reference" calibration. I have been messing around with REW the past few weeks. Something is not clear to me is with regards ...
Old 04-02-08, 12:45 PM   #1 (Link)
Alias: Rafael
Loc: Orlando
User: #17740
Since: Mar 2008
rafaelsmith is offline
Something is not clear to me is with regards to what I call my "reference" calibration point.
When I use a SPL meter and go thru my receivers test tones...I start with everything set to 0 then increase the AVR master volume until the SPL read ~75db for the front LET channel...then I adjust all the other channels to match. For me that comes out to a master volume of -20.0 (on the AVR display). So when watching movies I set the AVR master volume to -20.0..which I always assumed meant I was at "reference".
Yet when I do the check levels and such with REW...My master volume ends up around -34.0(on the AVR display) which shows 75db on the SPL meter.
Is this normal?
I ask because when I am finally done with all this and have done whatever EQing i end up doing...I would like to go back and make sure all 5 of my speakers and my SUB are matched...just not sure if I should not use the AVR's test tones anymore.
Old 04-02-08, 01:39 PM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: Question about "reference" calibration.
The volume setting you need with REW will depend on the sensitivity of the analog input the soundcard is connected to and the sweep level you have set in the REW settings. For matching your speaker levels your receiver's test tones would usually be best.
Old 04-02-08, 01:43 PM   #3 (Link)
Alias: Rafael
Loc: Orlando
User: #17740
Since: Mar 2008
JohnM wrote: View Post
Thanks....thats what I thought.
Its just that a 12-15 difference on the master volume...at least with my AVR is rather significant. At -35.0 master volume...I can barely hear anything...while at -20.0 the windows are shaking. Yet REW seems happy....plots come out pretty much near the 75db target.
Old 04-02-08, 03:05 PM   #4 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
On your receiver does the master volume go past 0db? This is generally what is called "reference level" pink noise should be 85db at 0db. Older receivers do not go by the same grid level and usually 0db is as loud as it goes. This is somewhat confusing for alot of people as receivers dont follow the general guidelines.
-35db as you said is usualy very soft but in your case -20 is very loud, this seems odd as there should not be such a dramatic difference between the two.
On my Onkyo I watch most movies with the master volume set at about -15db and that is comfortable.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Old 04-02-08, 03:11 PM   #5 (Link)
Alias: Rafael
Loc: Orlando
User: #17740
Since: Mar 2008
tonyvdb wrote: View Post
Honestly I have never bothered to go much past -15.
But this is what my manual says....so sounds like 0 is the max but it may allow to go past it..just wont display.
Volume Control
The volume may be adjusted either by turning the knob on the front
panel (clockwise to increase volume or counterclockwise to decrease
volume), or by pressing the Volume Control Buttons on the remote.
See Figure 62. The volume is displayed as a negative number of
decibels (dB) below the 0dB reference point, and may be changed
in 0.5dB increments.
Unlike the volume controls on some other products, 0dB is the maximum
volume for the AVR 247. Although it’s physically possible to turn the
volume to a higher level, doing so may damage your hearing and your
speakers. For certain more dynamic audio materials, even 0dB may be
too high, allowing for damage to equipment
Gonna do some tests tonight...but i am pretty sure that at 0 my SPL would be much higher than 85.
Maybe I am not doign things right....but with my SPL set at 70....all channel gains on AVR set to 0...a master volume of -20db equal 75db from the left front speaker.
Will see where the master volume ends up for 85db....my guess is 15-17.
Old 04-02-08, 06:57 PM   #6 (Link)
New Member
Alias: Marc
Loc: Viera, Florida
User: #15625
Since: Jan 2008
Magialisk is offline
I'm not sure if this adds much to the discussion, but just as another data point I usually listen to movies between -15 and -20 on my Yamaha. It can go above 0 though I'm not sure exactly how far, maybe to +8? I don't know why you'd ever be going above 0 anyway unless you're either deaf or calibrated extremely improperly.
When first setting up REW I calibrated the SPL meter signal (with the REW test noise) and it was 75dB at -20 MV. What is funny is how when you're done EQing if you go back and recalibrate the SPL meter signal I had to turn it up to -11 MV to get the same 75dB. Obviously when you're doing 10 and 12 dB cuts over wide areas of the sub-100Hz spectrum that test signal SPL is getting cut right along with the rest...
Old 04-02-08, 07:09 PM   #7 (Link)
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
Bill 3 is offline
Wouldn't your volume level/AVR output versus "reference" level depend on how effecient your speakers are?
Old 04-02-08, 07:12 PM   #8 (Link)
Alias: stephen
Loc: England
User: #16723
Since: Feb 2008
mojogoes is offline
I don't know if this may help too but on my old marantz depending on what level the intell volume is set say +5 / +10 then it would cut the master volume to say 0..........my onkyo 605 just goes from 0 /99.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Question on cruzmisl's "angled" front wall panel ? Hermit Home Audio Acoustics 3 12-07-07 04:46 AM
Question about HD DVD "The Ant Bully" fibreKid Movies | TV Shows | Hollywood 1 01-29-07 01:06 AM
REW "Left Channel" Calibration Question jaz123 REW Forum 5 12-26-06 09:09 AM
Velo SMS-1 calibration vs. sub "auto-on" MikeSp Home Audio Subwoofers 4 11-13-06 09:34 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
