Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Galaxy CM-140 C-Weighting in REW question
Discuss Galaxy CM-140 C-Weighting in REW question in the Subwoofer Equalization | Calibration forum; Galaxy CM-140 C-Weighting in REW question I see that the calibration file for the Galaxy SPL meter covers the range from 5 Hz up to 200 ...
Old 04-07-08, 11:27 PM   #1 (Link)
Alias: Dent
User: #416
Dent is offline
I see that the calibration file for the Galaxy SPL meter covers the range from 5 Hz up to 200 Hz. Now why has it been recommended to uncheck C-Weighting in REW? If doing our usual subwoofer response testing with REW (i.e. sweep from 0 Hz to 200 Hz), wouldn't we get the same result whether the C-Weighting in REW was checked or unchecked since I thought REW does not apply the C-Weighting inverse compensation (when checked) within the calibration file range?
If I wanted to measure the response higher than 200 Hz, let's say up to 1000 Hz or even higher, shouldn't the C-Weighting box be checked? Since I believe that you should get the same response when testing the 0 to 200 Hz range whether the C-Weighting is checked or not (and using the Galaxy calibration file), why not just leave it checked just in case one wants to measure a bit higher than 200 Hz?
I thought I saw previous posts by Ilkka where he tested his Galaxy CM-150 meter (which apparently should have the same response as the CM-140) all the way up to 20000 Hz or beyond and it was pretty close to his full range calibrated microphone. Again, if testing response up to 20000 Hz with the CM-140, the C-Weighting should be checked, right? When Ilkka did his testing with his CM-150 was there inverse C-Weighting compensation used?
Sonnie, when you were testing the CM-140 against your calibrated mic, how close was the response from 200 Hz up to 20000 Hz?
Old 04-08-08, 07:07 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Galaxy CM-140 C-Weighting in REW question
Previous versions of REW created the need for this recommendation when measuring to 200Hz. The C-Weight check box extended the area below the file end point (for the Galaxy from 5Hz down to 0Hz), such that it produced erroneous results. The latest version corrected this problem.
Would make no real difference with this version of REW.
Fine.
Yep.
We only tested and created a file up to 200Hz. You can't calibrate microphones against each other higher than that and obtain any accuracy. They must be sent for proper calibration.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Galaxy CM-140 & Fast/Slow setting for REW Dent SPL Meters | Mic's | Calibration 6 05-14-08 10:33 PM
Question about Galaxy 140 and M-Audio Mobile Pre mcallister SPL Meters | Mic's | Calibration 2 02-10-08 05:11 PM
Do I need a Galaxy CM-140 gerhardwessels SPL Meters | Mic's | Calibration 24 11-08-07 03:09 PM
Galaxy CM-140 drew01484 SPL Meters | Mic's | Calibration 7 05-25-07 08:33 AM
REW, newrsdigital.cal, and c-weighting question Dent REW Forum 6 05-28-06 12:50 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
