| REW Forum First Non-EQ'ed room response...Discuss First Non-EQ'ed room response... in the Equalization | Calibration forum; First Non-EQ'ed room response... OK, after playing with REW for about a week, I finally got a resonse curve for my HT room (I ... |
Views: 898 - Replies: 10
| First Non-EQ'ed room response... OK, after playing with REW for about a week, I finally got a resonse curve for my HT room (I know, minor achievement, but for the noobies like me a major victory). Is my room in need of some serious help? I plan on getting a BFD when it is in the budget, but for now I simply have to make do (Moving the subs is not an option, due to room constraints).... ![]() Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #3 | ||||
| Re: First Non-EQ'ed room response... Bruce, the subs are both SVS 20-39 PC+ tuned to 20Hz. Can I assume that the response below about 16Hz is "less than accurate" due to room response (I mean, shouldn't it continue to drop off here instead of going back up)? Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 07-20-06 at 11:30 PM.. | ||||
| | #4 | ||||
| Re: First Non-EQ'ed room response... Congrats Vader! man... when I first started working with the BFD it took me a week to hook it up and another week to take my measurements. lol Exaggerating obviously, but it definitely took me a while to figure it all out. If you are using the proper correction values then your response down to 10hz could very well be correct. I'm thinking really good room gain. How big is your room and where do you have the sub located? As your sig says... SVS doesn't leave the bass behind... ![]() | ||||
| | #5 | ||||
| Re: First Non-EQ'ed room response... Sonnie, The room is approx 3200 ft^3, and the subs are "kinda-sorta-pseudo corner loaded" (best I can do for the time being). In other words, the subs are about 6' from an actual corner on one side, and the fireplace on the other (which sticks out about 2 feet, at an angle of 135 degrees): ![]() Where F = the subs, K = Window shelf (closed), D = AV Rack, and E = Another shelf (LaserDiscs). I'm using the (new) calibration file for the old Rat Shack meter, the calibration for my soundcard (SoundBlaster Live Value), and C-weighting (doesn't seem to matter to the graph whether I turn it on or off?!?) Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 07-21-06 at 09:26 AM.. | ||||
| | #6 | |||||
| Re: First Non-EQ'ed room response... Quote:
If the Radio Shack meters actually had an accurate C-Weight response, then a .cal file to over-ride the mathematical C-Weight compensation provided by REW wouldn't be necessary. brucek | |||||
| | #7 | ||||
| Re: First Non-EQ'ed room response... The more I play with this, the more I think I messed up somewhere. A few more questions: 1) It seems pretty coincidental that my room curve and the target response coincide at 10Hz (81dB). Since my subs are in 20Hz tune, they should begin falling off rather sharply around 17-18Hz, but I reading from this curve that (allowing for some perturbations that require a BFD) it remains "flat" down to 10 Hz. Can room response do that? 2) When the measurement is made and the data saved off, is the data dependent on the calibration files loaded at the time? In other words, is the data saved in completely raw form , independent of calibration files, which can then be applied later, or do the cal files somehow influence how the raw data is recorded? 3) My soundcard calibration (the dotted line above at 75dB, right?) is almost perfectly flat, only falling off above 20k. Is this normal? Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #8 | |||||||
Or just look at the soundcard.cal file with notepad. It's easy to read. Here's mine up to 30Hz. See it drop off a bit starting at 20Hz. 10 -0.17 11 -0.11 12 -0.10 13 -0.10 14 -0.08 15 -0.07 16 -0.06 17 -0.05 18 -0.05 19 -0.04 20 -0.04 21 -0.02 22 -0.01 23 0.00 24 0.01 25 0.01 26 0.01 27 0.01 28 0.01 29 0.01 30 0.01 brucek | |||||||
| | #9 | ||||
| Re: First Non-EQ'ed room response... Bruce, my soundcard is a Soundblaster Live Value (only 16-bit duplex, not 24). Here is my cal file up to 30Hz. Does this look normal to you? 0 -19.795 1 -8.423 2 -3.121 3 -1.598 4 -1.106 5 -0.670 6 -0.566 7 -0.407 8 -0.353 9 -0.298 10 -0.258 11 -0.233 12 -0.208 13 -0.190 14 -0.178 15 -0.165 16 -0.157 17 -0.151 18 -0.143 19 -0.137 20 -0.134 21 -0.129 22 -0.125 23 -0.122 24 -0.119 25 -0.117 26 -0.113 27 -0.113 28 -0.112 29 -0.109 30 -0.108 For future measurements, do all of the parameters used in the generation of this cal file (measurement level, input volume) need to be exactly the same? Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #10 | ||||||
brucek | ||||||
| | #11 | ||||
| Re: First Non-EQ'ed room response... Thanx, Bruce. Assuming that the above graph is correct, I really have no need to go down to the 16Hz tune, and lose the headroom after all. Now, all I need is a BFD (I *might* have a few questions once I get it ). Someday, I'm hoping to understand enough about this stuff to just be dangerous....![]() Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
